Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 10-29-2009, 01:11 AM   #1
Default Glass block window in a plastic tub surround?
I'm planning on having a plastic tub surround installed over the old tile in my shower. I currently have a vinyl window in my shower and would like to replace it with a glass block window, but I didn't know how that would work with the tub surround. Is it possible to cut the surround around the block window and trim it somehow? If so, does anyone have any advice or pictures of how I could do that?
CubsWin is offline   Reply With Quote
More On This Topic
You can choose many different sizes and styles of glass block for decorating. The block comes in 4- to 8-inch squares and in a variety of smooth, textured, clear, and diffused styles. Before choosing your glass, decide how and where it will be used, so... Read More »
Hi, I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. One thing to remember when plumbing your basement, is that the location of the toilet is not as important as it first may seem. Where that pipe is sticking... Read More »
Cleaning can be monotonous and if you have a glass shower cleaning can be an even bigger pain. There is an easy way to keep the glass in your shower cleaner longer so you can spend more time doing what you really want. Read More »
This has likely happened to nearly everyone: you pull open your shower curtain and find that one or more of the holes at the top have torn away from the shower hook. Save yourself a few dollars and repair that torn hole on your vinyl shower curtain... Read More »
The bathroom is a notorious place for germs to grow and thrive. It's also a typical haven for mold, mildew and fungus of all kinds. The damp atmosphere and general lack of proper air circulation in most bathrooms are major contributors to this sorry... Read More »
Installing vent in glass block window jasoncw Building & Construction 6 09-27-2009 12:57 PM
Building a Glass Block Window mdonald11 Building & Construction 0 09-18-2009 09:55 PM
Impact Windows & French Doors Matty16 Carpentry 6 06-22-2009 11:01 PM
Condensation on fiberglass window frame creamaster General Discussion 9 11-24-2008 08:40 AM
Glass block window position?? justdon Remodeling 4 09-28-2008 08:29 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
