Glass Block In Bathroom - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-20-2008, 01:24 PM   #1
Rewards Points: 107
Glass Block in Bathroom
Hello, I am remodling my bathroom and wanted to replace the bathroom window (in the shower wall) with a glass block window. I have all the plaster walls taken out to the studs so I can see the frame that holds the window in. My first problem is how do I measure the window opening? The house is brick and the sill on the outside is at an angle up to the window so will I have to take out the window to measure for a correct size? If anyone knows of a good tut or images please post. My second problem is how much gap should I have around the edges for the morter when I order my window?
Thanks,
Chad
oxicottin is offline   Reply With Quote
Old 04-21-2008, 03:59 PM   #2
Rewards Points: 818
Start here:
HOME IMPROVEMENT : Installation : Installing a Glass Block Window: Prep Work, Remove Windowsill and Cut Out Interior Side Hol...
LawnGuyLandSparky is online now   Reply With Quote
Old 04-21-2008, 04:09 PM   #3
Rewards Points: 107
Thanks for the link it is a little helpfull...
Installing vent in glass block window jasoncw Building & Construction 6 09-27-2009 11:57 AM
Glass block window position?? justdon Remodeling 4 09-28-2008 07:29 AM
Glass Block basement windows Colonial Building & Construction 2 03-18-2008 01:20 PM
Glass Block jtbroderick Remodeling 1 04-16-2006 03:37 PM
