Get Scratches Out Of Granite - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-10-2009, 11:45 PM   #1
Get scratches out of Granite
I bought a floor model vanity top from the home repair store. It had a few scratches, so I got it for a song. Now, I need to know how to repair the scratches. There are a few scratches that just barely make an indention, but there are two larger and slightly deeper ones. With the pattern, you can't really see the scratches unless you look for them, but it will drive me nuts if I don't fix them.
Any advice?
Here's what the vanity top looks like: http://www.homedepot.com/webapp/wcs/...ctId=100042025
MeraleeCrowl is offline   Reply With Quote
Old 01-11-2009, 12:27 PM   #2
Remodeling Contractor
The factory finish will be impossible to completely match. To do the best you can you need to polish the scratches out with diamond grinding pads. Start with 500 grit then 1000 1200 1500 8500 then tin oxide then stone enhancer. You will need a wet grinder to do this and knowledge of the process would not hurt.
Old 01-12-2009, 12:47 PM   #3
Rewards Points: 5,336
Another approach would be to fill the deep scratches with a clear epoxy and then follow Bob's advice.
Ron
Old 01-12-2009, 01:34 PM   #4
Ron
That is what I was thinking would be possible for the two deeper scratches (they are less than half a milimeter deep). The others are simple surface scratches.
Old 01-12-2009, 01:52 PM   #5
Actually you should color the epoxy to match our granite it will show. If you can sink a finger nail into a scratch it is considered a deep scratch and should be filled as suggested.
Stonemark & Silestone Countertops......??? DepotDweller Remodeling 9 06-25-2009 11:44 AM
Using granite & laminate for kitchen Jetboy55 Remodeling 5 08-10-2008 09:56 AM
Decorative Etched Granite Listello csteinke Remodeling 1 06-08-2007 11:54 PM
