Gel Fireplace? - Remodeling - DIY Chatroom Home Improvement Forum
Old 12-27-2011, 08:52 PM   #1
DeeKayVB's Avatar
Gel fireplace?
I've seen ads for a gel fireplace that you can stick anywhere. Anyone have experiences with them? I have a wood burning one that I want to do something with that will improve energy efficiency. I have no gas line.
DeeKayVB is offline   Reply With Quote
Old 12-28-2011, 09:16 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 606
Ayuh,... They work Great,....
For anything BUT Heating...
Bondo is online now   Reply With Quote
The Following 2 Users Say Thank You to Bondo For This Useful Post:
BigJim (12-28-2011), DeeKayVB (12-28-2011)
Old 12-28-2011, 09:25 AM   #3
DeeKayVB's Avatar
I suspected as much ... so what is the best option for heat and mostly energy efficiency in an existing wood burning fireplace?
Old 12-28-2011, 11:52 AM   #4
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
We put a wood burning insert in our old fireplace.
Even if we never light a fire it will eventually pay for itself since it basically plugged the huge heat sucking hole that was our old fireplace.
Old 12-28-2011, 02:10 PM   #5
DeeKayVB's Avatar
I stuffed pillows in garbage bags in mine. Did cut down on the power bill a lot but not the final look n functionality I would like ...
Old 12-28-2011, 03:06 PM   #6
Rewards Points: 13,270
Insert or gas logs.
Need opinions on tearing out old fireplace Dwillems Building & Construction 9 09-06-2011 12:37 PM
Fireplace construction question scottyv81 General DIY Discussions 1 01-29-2011 10:26 AM
Fireplace Smell ...help wanted ! jasonb72 General DIY Discussions 6 08-26-2010 07:02 PM
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 07:12 PM
Possible to build direct-vent fireplace? DIYerself General DIY Discussions 3 12-22-2007 11:07 PM
