Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 12-17-2012, 08:48 PM   #16
Gas line - move?
Originally Posted by gregzoll View Post
There is no physical gas in the line when it is flowing. Natural gas is a vapor, not a Liquid. LPG flows as a vapor, not a liquid. Only fuel that is a physical liquid would be heating oil.
Once you shut off the main at the meter, open the line there is no danger. Even if there is a leak while working on the line, and you are able to stop it, there is no danger. It takes a high amount of vapor in an area that would cause a danger, if there is a spark.
yes, i know that it is a vapor.
what i didn't know is that there isn't enough in the line to make it a problem.
thanx
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
Old 12-17-2012, 08:50 PM   #17
Average Joe/ex-Navy IC3
gregzoll's Avatar
Gas line - move?
No, there is nothing in the line to be a problem. Only with fuel oil would there be something in the line that can cause a problem.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 12-17-2012, 09:45 PM   #18
Gas line - move?
that is good to know. as i have about 20' that i need to remove.
Old 12-17-2012, 10:14 PM   #19
Gas line - move?
This subject of no non licensed people even thinking of touching a gas line is really puzzling to me. Possibly so because from an early age I've never ever considered paying to have gas line work done. In later years I've retired from natural gas compression from the time it came from the dirt deep down mixed with water, propane and all those other unwanted tanes ranging from nearly a vacuum to 1,200 lbs. pressure on lines from 1/4" to 12 inches. Screwed fittings, flanged fittings AND yes the ever so dangerous and absolutely no good compression fittings that a good number of licensed professionals don't have a clue how to correctly connect.
But it seems to be just fine for the non licensed home owner DIY- er to monkey around with electrical they know very little about.
Have you ever smelled electricity when it was becoming dangerous and about to instantly kill you on the spot or to you and your family's well being and about to cause your house to burn? I doubt it. It doesn't yet have mercaptan to warn us.
Natural gas has a upper and lower combustible limit it must be within to even burn. The average is 5 to 15 percent fuel ratio to air for NG and Propane is 2.1 to 10.1 percent. Have you ever seen electric cut you that much slack? I doubt that one too.
Fairview is offline   Reply With Quote
Old 12-17-2012, 10:21 PM   #20
Moderator
Gas line - move?
Keep minimum code in mind for safety;
"G2415.3 (404.3) Piping in concealed locations. Portions of a piping system installed in concealed locations shall not have unions, tubing fittings, right and left couplings, bushings, compression couplings, and swing joints made by combinations of fittings.
Exceptions:
1. Tubing joined by brazing. 2. Fittings listed for use in concealed locations" From; http://publicecodes.cyberregs.com/icod/irc/2009/icod_irc_2009_24_sec015.htm
Gary
Clothes taking longer to dry?
Old 12-17-2012, 10:37 PM   #21
gregzoll's Avatar
Gas line - move?
Fairview, as long as a person uses common sense when working with the piping, it it no different than running potable water lines.
The dangers lie, when people ignore the smell or a leak and sign it off to a nothing.
I have been around this stuff all my life, due to my grandpa owned a major construction company here in Illinois, grew up watching my father do electrical, plumbing and gas piping.
It is not Rocket Science and entailing that there is a great fear if you even touch a gas line or fittining will blow you up, is just telling people that they are ignorant and you are the only one that is God and should be the only to do this stuff.
I can tell you this, more accidents and headaches are caused by those in the trades trying to hirry up and get the job done, or creating a band-aid, thane taking their te to do the job right.
And when does the before mentioned happen, in the homes or on the peoperty of those in the trades.
Moving service panel away from main service line entry k2000lbs Electrical 3 11-28-2011 09:39 AM
Proper Water and Gas line bonding. John318 Electrical 5 11-16-2011 12:19 PM
Outdoor Underground Natural Gas Line Vikeologist HVAC 13 10-26-2011 12:46 PM
Can a roof vent identify where my main sewer line exits the house? YerDugliness Plumbing 8 01-26-2010 05:13 PM
Need to move a tub drain to line up with a new tub, is it ok to do this... *PICS* J187 Plumbing 6 05-23-2006 12:13 AM
