-   -   Garage Door Insulation Kit (http://www.diychatroom.com/f15/garage-door-insulation-kit-35890/)
diyDude_2 01-14-2009 01:17 PM
Does anyone know how much money can be saved installing a garage door insulation kits? My garage door is currently not insulated - I'm just not sure of the actual potential cost savings. These are relatively inexpensive (http://www.doorinsulationkit.com) - Especially compared to replacing the whole door. Any challenges installing these? Thanks!
Reilley 01-15-2009 02:34 PM
Well that depends on a few things.
1) Is this an attached garage?
1b) If attached, are the inside walls / ceiling insulated from the rest of the house?
2) Do you heat the garage?
3) What type of garage door do you have? Mine is older and has been fitted with rigid foam / wall panelling to hold it in by the previous owner.
diyDude_2 01-15-2009 11:51 PM
See my answers below:
1) Is this an attached garage? --- Yes
1b) If attached, are the inside walls / ceiling insulated from the rest of the house? --- I'm assuming that the wall facing the garage is insulated, but I'm not 100% sure.
2) Do you heat the garage? --- No, I do not heat the garage
3) What type of garage door do you have? Mine is older and has been fitted with rigid foam / wall panelling to hold it in by the previous owner. --- I believe it is aluminum (it is metal of some sort). Thanks!
