Garage Door - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-29-2014, 10:14 PM   #1
Garage door
How hard or easy is it to heighten a garage door? The door is plenty wide just need a bit taller. Plenty of room from existing door to the eave or roof.
Hwhite8011 is offline   Reply With Quote
Old 04-30-2014, 07:12 AM   #2
Rewards Points: 144
What do you call "plenty of room"?There is usually a 12" header that fills that space and is needed to support the span.
mako1 is offline   Reply With Quote
Old 04-30-2014, 08:08 AM   #3
There is at least another 2' to the roof.
Sent from my SCH-I545 using Tapatalk
Old 04-30-2014, 08:26 AM   #4
Rewards Points: 144
Should not be a problem then.You will have to shorten the the cripples above the header.Then raise the header and add longer jack studs to support the header.
Old 04-30-2014, 08:30 AM   #5
Rewards Points: 14,010
Got a picture of the inside and out in that area?
What type siding?
Is there cripples above the header, if so how long are they?
Single story?
Old 04-30-2014, 08:51 AM   #6
No pics, house hunting. Found a possibilty, just too short in the garage door. LP siding, which will be changed if we purchase. Single story.
Old 04-30-2014, 02:44 PM   #7
DIY staff
Rewards Points: 7,174
You should be able to find drawings of typical garage framing in the library--or on the internet--that will give you some idea --there is a header above the door---sometimes a rather large one---
The issue is the amount of open space above that headed and the top of the wall--before the roof trusses---
Garage door chain hopped off--how to fix (w/o adjustable slack)? EricBNeverScare Windows and Doors 5 07-10-2013 09:20 AM
Garage door repair help word2yamutha General DIY Discussions 12 04-04-2013 08:10 PM
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
Garage Door Assistance dukes32 General DIY Discussions 2 06-15-2011 12:11 PM
Old Genie Garage Door Opener cmgith General DIY Discussions 3 11-27-2006 08:53 PM
