Garage Ceiling Options - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-10-2012, 12:38 PM   #1
Garage ceiling options
I have a detatched garage and im planning
To hang drywall, for the ceiling i am looking for another option other than drywall (easier option) is there any?
Ckb3216 is offline   Reply With Quote
Old 03-10-2012, 02:25 PM   #2
Rewards Points: 2,212
Depending on where you live and what is allowed. I have done the 'barn' metal on ceilings (and walls), also plywood or OSB, Also 1x4 or 1x4 t&G pine or cedar.
mae-ling is offline   Reply With Quote
Old 03-10-2012, 02:42 PM   #3
I live in long island,ny i heard about the metal? I just want somethinf easy to install dont want to mud and tape up on the peak ceiling
Old 03-10-2012, 03:31 PM   #4
retired union carpenter
Send a message via Yahoo to coupe
I have put 1/2" fiber sound board on ceilings. much lighter than drywall, is brown 4'x8' sheets. still cuts with utility knife. maybe 25 pounds a sheet? easy hanging by yourself
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Old 03-13-2012, 12:23 AM   #5
Things that you are thinking of are not so easy my Dear. sometimes a drywall creates problem.
mathewross is offline   Reply With Quote
Old 03-17-2012, 07:38 PM   #6
In a little over my head
Rewards Points: 706
May not be an issue since it's detached, but check code for fire resistance.
ratherbefishing is offline   Reply With Quote
Old 03-17-2012, 08:01 PM   #7
Rewards Points: 13,740
Worry me when you said peaked ceilngs. Are you thinking of not having a real ceiling but a catherdral ceiling instead? If so that brings up a whole list of issues that would need to be addressed.
Any code I've ever seen is 5/8 fire code drywall on garage ceilings.
Please do not to the so called brown board or black board, also called Celotex. read what it says right on the face of it. Flamable, must be covered.
It also does not hold nails worth a darn.
There's no reason you could not just hang the sheetrock and only tape it and apply one coat of mud and not finish it.
Detached Garage, Raising Ceiling Rafters?[pics] alecmcmahon Building & Construction 13 05-30-2010 12:30 PM
Lighting Options for a dropped ceiling basement markronz Electrical 11 04-20-2010 02:20 PM
Garage Heater Wiring ceiling penetration Question DenverBob Electrical 5 12-28-2009 01:01 PM
garage ceiling mferguson0414 Carpentry 2 01-13-2009 10:24 PM
Drywall Garage Ceiling Recommendations jsjames Building & Construction 6 08-22-2007 03:47 PM
