-   -   Gaps between dywall and carpet on stairs (http://www.diychatroom.com/f15/gaps-between-dywall-carpet-stairs-135180/)
Mills314 02-26-2012 10:15 PM
Hey guys, finally getting around to working on the stairs in the new house, and the previous own was nice enough to have carpet installed with large gaps between the stair treads and risers. We are talking about 1/4 to 1/2 inch.
What are my options? Some kind of molding? Stair skirts?
Thanks!
joecaption 02-26-2012 10:17 PM
Without a picture it's anyone guess.
Mills314 02-26-2012 10:25 PM
1 Attachment(s)
Attachment 46591
joecaption 02-26-2012 10:31 PM
Is this in a basement with a concrete wall behind the sheetrock?
Thanks for the picture but your standing to close.
I'm trying to figure out why there was no skirt and the drywall was not run down behind skirt and stair treads.
Mills314 02-26-2012 10:45 PM
No concrete. The stringers are secured to the walls of the stairwell. Then the sheetrock was put in after the treads.
Yeah, awesome job.
I know, whatever I do isn't going to be the 100% solution. But I would like to do something that conceals it and looks nice as well.
joecaption 02-26-2012 10:49 PM
Unless that whole thing is redone so the stringer is held off the wall with a 2 X 4 behind it to space it out for a skirt and the rock to go behind it I see no pretty way to fix that mess.
Someone else may come up with an idea.
BigJim 02-27-2012 01:19 AM
It is hard to tell from the pictures could you make a couple of shots of the stairs over all?
If you want to install a skirt board here is a link that will show you an easy way to do it.
http://www.diychatroom.com/f14/stair...te-easy-42845/
chrisBC 02-27-2012 03:08 AM
Skirting boards
Or maybe even some quarter round would do the trick, not sure if i've ever seen that done with carpet, but might work..
Mills314 02-27-2012 06:55 AM
Your basically saying, create a 90 degree on the riser, and taking it out the tread as well and finishing it off with a bevel?
chrisBC 02-27-2012 01:05 PM
For quarter round? Yes, I think I am thinking the same thing.. depends on what you have for a nosing..
I would just try a few pieces and see what works and looks the best.
mae-ling 02-27-2012 03:04 PM
Picture a little further away would be good if possible.
If it s as I think then what I have done is use some flat moulding. 1.5" and 1/2" thick and put it on the wall cutting all the angles and all the pieces, a little tedious but it looked good when done.
Mills314 02-27-2012 11:01 PM
I'm willing to put in the tedious work as I have no choice. Do you have an example of the molding and a picture of the finished product by chance?
Just to clarify, your talking about putting the molding between the riser and drywall, then cutting at a 45 degree angle and taking it straight out between the tread and the drywall? Almost like an L on each side if each step?
mae-ling 02-28-2012 11:11 PM
Not my work but similar to what I did. And everything will not be 45degree cuts! It looks like you could use smaller moulding. Do your treads have a nosing?
http://2.bp.blogspot.com/__mLrFBgP2h...air-treads.jpg
Mills314 02-29-2012 07:02 AM
Just a standard rounded nosing, maybe 3/4 of an inch. I'm guessing just notching that out on each step?
mae-ling 03-01-2012 01:08 AM
Yep, notch the verticle trim piece.
