Gap At My Front Door - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-26-2008, 02:29 PM   #1
Gap at my front door
Background:
I'm in a condo, and recently put in tile floor in my entryway... long story short, the concrete floor was not level, I grinded it down enough to make only a slight slope in the floor, and its not noticable in the new tile (luckily).
However, the door now has a visible gap at the threshold. Previously, the door would push down the pile of the carpet (carpet didn't even have room for carpet pad).
My Problem:
I need some way to actually raise the threshold up about 1/2" to 3/4" and close the gap of the door. Anything I attach to the door (weather stripping, etc) will rub as the door opens. The door barely has any clearance when it all the way open, but when closed has this large gap.
The threshold now, is a rubber transition piece that gaps the hallway carpet and the tile I've installed (same piece that was there when it was carpet).
I can't find any product that really meets my need, and I really don't want to do any more major work, are there any suggestions?
Thanks for your help,
Chuck
ChuckF is offline   Reply With Quote
Old 07-26-2008, 02:47 PM   #2
Registered User
Termite's Avatar
Chuck,
Is your threshold adjustable? You could replace the threshold with an adjustable one, and raise one side higher than the other. They have adjustment screws.
Or, you could install a basic fixed threshold and build up the floor under one side or shim one side to raise it up to bridge the gap.
Help with FRONT DOOR threshold....(pictures) Bobrobert General DIY Discussions 11 11-24-2008 07:32 PM
replacement front door is hanging crooked norway Carpentry 2 07-12-2008 06:38 PM
Entry Door---My Story----Advice Please rossmoor Building & Construction 3 02-29-2008 10:13 PM
Front door installation - couple q's joeyboy Building & Construction 3 08-19-2007 03:35 PM
