09-12-2008, 02:00 AM
#1
Gap in Corner Between Tub Surround and Bathtub?
Hi!
I bought a one-piece (rounded corner) tub surround ( http://www.maax.com/en/Products/Prod...=8&Product=804) to use with this bathtub ( http://www.rona.ca/img/product/full/2003013.jpg) which has square corners.
My problem is when I dry fit the tub surround with the tub there is a gap in both corners because the tub surround is supposed to go along the tiling flange. The tiling flange is about 1.5" above the tub edge surface so there is an exposed gap in the corners (because the tub is square and the tub surround is rounded at the corners. The exposed area is about 1.5" high and extends from the rounded corner of the back wall to the rounded corner of the side wall (see picture below). Is there any practical way to cover over this exposed area? It would take a great deal of silicone to cover this, so I'm not wanting to do this (and it may look bad too)....
I took a pic:
What can I do about this besides take the surround back? My wife cut up the box already for the kids! Any ideas?
??? Help!
09-12-2008, 09:20 AM
#2
Short of having someone come out and fiberglass it together, I don't think it will ever look right, that much caulk would really junk up your project. I'd would either 1.) look for a surround that fit that tub design, or 2.) find a tub that fit the surround, 3.) install a tile surround.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
09-12-2008, 04:49 PM
#3
What about getting a tub resurfacer (such as "Bathfitter") to fill the corner for me? How would this look?
09-13-2008, 12:35 PM
#4
Another idea (maybe a crazy one)... I would have to cut off about 3" of the tub surround along the entire edge on both ends, I wonder if I could use a small piece and sand/trim it up with my Dremel tool so it fits nicely into the corner gap, then cover the edges carefully with silicone. Would this look ok?
09-13-2008, 12:36 PM
#5
I might have to return it to Home Depot. I have already glued in the foam corner pieces to the wall so I would have to cut them off the wall. The wife has also cut up the box for the kids, so I would have to tape it back together.
One good thing is that I haven't cut into the surround at all, knowing that I might have to take it back to the store.
09-13-2008, 01:27 PM
#6
Building codes guy, Mod
I'd return it or sell it. It will never look good. Outfits like Re-Bath and Bathfitter simply install covers over the tub, that are made brand-specific to the tub. There's very little actual craftsmanship involved with their installations and I doubt they can help you.
09-13-2008, 11:44 PM
#7
My wife's uncle said that if Home Depot won't take the surround back, I should cut the surround straight down at the two corners and make it a 3-piece (and square corners)... Then I would have to apply silicone in the corners... how does this sound?
09-14-2008, 02:31 AM
#9
Honest answer? It'll look like a hack job. If you've done all this work it would be a shame to cob it together to save the cost of a new one.
Put the old one for sale on craigslist or something like that. Or you could donate it to Habitat For Humanity and take a tax deduction. Either way, you can recover some of your money. I doubt HD will take it back without the packaging and once it has been installed (they shouldn't!), but you never know.
09-14-2008, 11:53 AM
#10
I taped the box back together, so it is complete (my wife cut it into about 10 pieces for the kids, but it looks ok when taped back together.) I still have to remove the foam corner off the wall (they are secured with two-sided tape and adhesive, so I might have to cut them off with a utility knife). All the materials will be in the box, plus I didn't cut up the tub surround at all)... I'm optimistic HD will refund me my money back.
09-14-2008, 01:38 PM
#11
BUILDER / REMODELING CONT
I hope for your sake they take it back. It does appear that the walls don't match up to the style tub you have.
The give away is that the box is all taped up, I purchased a cast iron sink from HD once when I took it to the job and opened it up, I had a hell of a time trying to open the box, it appeared to be stapled like normal, but it was glued with Formica glue or some type of rubber cement. well when the box was opened it revealed an old sink. some one made the switch. when I brought it back they looked at me as if I had three eyes. They did re founded my money. Good luck.
09-17-2008, 01:27 AM
#12
Yay!! Home Depot accepted my return!
09-17-2008, 05:14 PM
#13
glad it worked out for you
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
