Furring Strips - Do I Need Them? - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-06-2011, 03:57 PM   #1
Furring Strips - Do I need them?
I'm starting to plan for finishing my basement, and I want to make sure I'm getting off on the right foot. So far my plan is (1) identify moisture and deal with it (currently the only moisture I've seen has been drylocked), (2) Glue on rigid foam insulation, (3) frame
I'm wondering what the benefits of adding furring strips to this process would be, if any? Do people usually use furring strips if they plan on setting up a frame using 2x4s?
ctote is offline   Reply With Quote
Old 07-08-2011, 07:07 AM   #2
There are 2" rigid foam sheets that have notches in them for furring strips(24"c). The furring strips anchor the foam to the foundation wall and also provide mounting for drywall. No wall framing needed. But if you want to frame out a wall, keep it several inches in from the foundation wall. Any wood touching concrete should be pressure treated.
Old 07-08-2011, 08:11 AM   #3
I'm worried that if I don't frame out the wall, it won't meet code for when we try to sell.
Would it work to glue the board to the wall and then put up a 2x4 frame right against that?
Old 07-08-2011, 09:35 PM   #4
Rewards Points: 5,336
If you get the job inspected and an updated C of O, the job is on file as being up to code.
What am I missing here?
Ron
B. Franklin 1759
Old 07-09-2011, 07:59 AM   #5
Rewards Points: 1,536
If you have framing then you don't need furring strips.
Old 07-13-2011, 05:31 AM   #6
Cape Cod, MA
Rewards Points: 81
Im new to this and will be going through the same as ctote. The furring strips need to be pressure treated? Im assuming they should be anchored with a ramset or hilti?
Thanks.
Aaron
capecodder is offline   Reply With Quote
Old 07-15-2011, 01:02 AM   #7
I wouldn't bother with the furring if you're framing...
design_lover13 is offline   Reply With Quote
Old 07-16-2011, 08:09 PM   #8
Registered User
Rewards Points: 526
capecodder, see note #7; http://publicecodes.citation.com/ico...9_3_sec017.htm
Gary
The Hows and Whys of Furring Strips. Part-1 Willie T How To Guides 12 03-01-2013 02:58 PM
What size screws for furring strips on rafters TomFl Building & Construction 1 03-15-2010 07:59 PM
Attaching 12/2 wire to Furring Strips blaze01 Electrical 2 02-17-2010 01:17 PM
Plywood over furring strips? sandyman720 Roofing/Siding 5 01-19-2008 09:46 PM
Best furring strips? J187 Building & Construction 5 06-03-2006 09:41 AM
