#1 |
furring ceiling
I am in the process of finishing a basement, I need to furr down the ceiling to level it (the 2x10 joists in the ceiling are of course not all perfect)... I am using 2x4x12s as the furring medium, mainly since it gives more room to screw into and they are easier to get straight and true.
I wanted to do this 16" O.C. but after measuring I can not fit recessed can lights into the space that would be left.. 24" O.C. would give more then enough space since the furring would run perpendicular to the joists, the box left is too small for the cans I was going to use (6" cans) is 24" O.C. adequate for ceiling furring and 1/2" drywall? the furring would be secured at every joist (floor joists are 16" O.C.) WITH 3" coarse screws anything wrong with this? if so please stop me now!
#2 |
furring ceiling
I'm not sure I understand why a 6" can wouldn't fit inside a 16" joist space. It's an industry standard so its hard to believe the can wouldn't conform to this dimension. Regardless, 1/2" drywall will sag when using 24" c/c
#3 |
furring ceiling
we're not talking about a 16" joist space, this is a joist space that is now broken up by perpendicular furring, which drastically reduces the space the can's mounting arms can move, I can't even push the can up into the space that 16" OC furring gives me
#4 |
MarginallyQualified
furring ceiling |
#5 |
furring ceiling
can you get resilient channels that are 1.5" to 2" high? I do have water lines to deal with that I am trying to fur down from also in one part. If so who sells them?
#6 |
furring ceiling
Here we can get 1/2" ceiling drywall that will do 24" span.
The channels are a good idea. |
#7 | |
furring ceilingQuote:
but this new stuff definatly is lighter then the older stuffany good reads out there on the resilient channels? I always seem them in home theater builds, but never thought much about them myself |
#8 |
furring ceiling
well, I should of remember this from before... 6" can's can be modified to fit 12" O.C.... can't believe I forgot that, I did a test modified can and it fits perfectly into the spacing now since I only have 12" of space when 2x4's on 16" O.C.
#9 |
furring ceiling
well now that I have the reccessed light problem out of the way, thought of something else
do the ends of the furred ceilings need to be blocked between furring strips also so the drywall has a screw ledge on the ends of the panels instead of just running down the lengths? or is the furring strips enough? |
#10 |
Soundproofing Guy
furring ceiling
I would not recommend RC-1 resilient channel, but RC-2 resilient channel would work well. Better to use 7/8" drywall furring channel, as this is spec'd by the SSMA.
#11 | |
the channel is 7/8" I assume this is a Hat style channel that uses a clip? if so do you happen to know how far it can be furred down with the clip? I need about 1.5" of clearance for furring |
#12 |
Soundproofing Guy
furring ceiling
They make a 1 1/2" tall furring as well. Could be called RC-2 or 1 1/2" Drywall Furring Channel
Generally every community has access to a commercial distributor that handles drywall, insulation and steel framing. These commercial guys will generally have the channel you want |
#13 |
furring ceiling
I was just looking at 1-1/2" DWC Hat Furring Channel seems like its the best for my situation, anyone know where you can buy this stuff at?
#14 | |
| Display Modes | |
| Plaster ceiling with peeling paint | annaem | Painting | 14 | 01-19-2012 01:10 PM |
| Garage ceiling joists and beam question | Truth | Building & Construction | 8 | 01-05-2012 08:52 PM |
| Paint peeling off Bathroom Ceiling!!! | armen30 | Painting | 17 | 12-08-2011 09:26 AM |
| Installing Furring Strip - basement ceiling | nsanto17 | Building & Construction | 8 | 12-30-2010 04:28 PM |
| Ceiling Repairs and Muresco Paint: Seamless Paint Job Possible? | Lovegasoline | Painting | 4 | 11-25-2009 03:06 PM |
