Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 11-18-2009, 12:31 PM   #1
furnace noise
Our garage was converted into a living room. The furnace is in here and a closet was built around it . It all looks very nice but the furnace is noisy. We can insulate the solid walls behind and to the side, but is there anyway to insulate the door. Its an accordion slatted door.
debd is offline   Reply With Quote
Old 11-22-2009, 10:19 PM   #2
furnace noise
I will go ahead and say no. The reason for the slant door is for the furnace and water heater to to get air. The only way to sound proof the door would be to get a solid door but that would suffocate the furnace and water heater. Over here where I live you have to have a slant door or large slant covers on the wall going to the room. Sorry you might be S O L on this one unless someone else can chime in with a idea and let me know I'm wrong.
Holt is offline   Reply With Quote
Old 11-27-2009, 01:20 PM   #3
furnace noise
Can you install vents or louvers to the outside to give the furnace its air?
This would kill two birds with one stone: reduce noise, and not exhaust heated (interior) air to the outside as the furnace runs.
The louvered door would then be replaced wiht an insulated door.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 11-27-2009, 01:40 PM   #4
furnace noise
The furnace is against an inside wall so the only place to put the vent would be through the attack and roof (which seems like a lot of work) or through the floor and vent it into the crawl space. Would this be a problem and how big would the vent have to be?
Old 11-28-2009, 10:25 AM   #5
Drywall contractor
furnace noise
Might be best to ask on the HVAC forum. There are probably some pros there that can give a definitive answer....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 11-28-2009, 01:10 PM   #6
furnace noise
Good Idea thanks
Brand new Coleman 97.5% furnace makes horrible whining noise junebuggy HVAC 7 05-07-2010 11:24 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
Furnace blower motor noise rivershorereid HVAC 1 10-04-2008 03:31 PM
Williams wall furnace whistling noise diyer_mi HVAC 11 10-23-2007 05:05 PM
