FRP Adhesive Trowel Size? - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-12-2014, 02:49 PM   #1
Rewards Points: 117
I am going to be installing a 4 x 4 piece of FRP on a smooth surface. (drywall) What size v-notch trowel is recommended to spread the adhesive?
tommyxv is offline   Reply With Quote
Old 04-12-2014, 04:03 PM   #2
Oso954's Avatar
Rewards Points: 1,636
The notch size/spacing depends on the adhesive mfg.
Oso954 is offline   Reply With Quote
Old 04-12-2014, 05:12 PM   #3
Rewards Points: 117
OK, I'll have to check out the info on the bucket when I pick it up. Thx
Old 04-12-2014, 08:26 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,334
drawing from memory you should be using the smallest vnotch trowel you can get. frp is very thin and has a pretty smooth back so you want even coverage and have it so it doesnt create bulges under neath the panels
woodworkbykirk is offline   Reply With Quote
Old 04-13-2014, 08:16 AM   #5
Rewards Points: 117
Looks like 3/16" x 1/4" V-Notch will do the trick. Thanks
Proper trunk/duct size? gjones HVAC 7 12-06-2011 07:18 PM
Tub Tile Surround Question GrooveMerchant Kitchen & Bath Remodeling 15 11-26-2011 09:01 PM
Trowel size help Abs777 Tiling, ceramics, marble 1 08-31-2011 08:18 PM
Building a patio cover...span and size of lumber Q's jongordo8 Building & Construction 1 08-30-2009 12:08 AM
Anyone know where to find a 5/16" x 5/16" V Notched Trowel? fjlcisco21 Flooring 5 08-12-2009 04:58 PM
