-   -   French drains in basement (http://www.diychatroom.com/f15/french-drains-basement-52794/)
Sephora 09-11-2009 09:38 AM
We have a Colonial type house with a full basement. The previous owners divided the room with sheet rock and made a door in between.
Since there is electrical down there and a ceiling fan already we thought we could easily finish off the half for a playroom/tv room for the kids. So one long wall is up but the other two are basement cement.
We have french drains along the perimeter. When putting up walls what do we have to do?
Sorry I am clueless and my husband def is more than me.
concretemasonry 09-11-2009 12:04 PM
Is this a "real" French drain (under the slab and along the bottom of the footings) or just a cheap plastic molding at the base to collect the water that has already leaked in?
Dick
Daniel Holzman 09-11-2009 12:17 PM
Perhaps you could tell us what you are trying to do, I could not understand your post. Are you concerned about water in the basement, and are wondering how to control it? Are you concerned about the possible effect of French drains on your walls? Or is this post about how to finish the basement?
Sephora 09-11-2009 12:27 PM
They are real frech drains that look like they were built into cement along the bottom. They are a dark color.
I am asking that if we want to put up walls what do we have to do.
For the record, we don't get water in our basement. We have a sump pump on the other side of the basement that has never been plugged in. Supposedly, the last owner said he got it installed as he started to remodel it down there and never finished.
concretemasonry 09-11-2009 03:32 PM
Any drain that you can see is not a real French drain, that must be installed at the level of the footing and under the slab.
What Sephora is describing is just a collection system inside the basement that may have been installed after construction or as cheap last minute addition when the slab was poured.
Anything in or on the slab is just a collection system for water that has already leaking into the home. A real French drain collects the water from below and lowers and eliminates the water table around the house, reducing the pressure on the foundation and limits the amount of water that could find its way in if exterior waterproofing is not adequate.
Sephora 09-14-2009 08:18 AM
Ok, they told us it was French drains when we bought the house. Regardless, we still need to put up walls on 2 sides that have these "drains". What do we need to do in order to do this?
