French Doors - Outswing - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-06-2010, 10:38 AM   #1
I have heard that there is a safety issue with the hinges on outswing french doors - burglars could just remove the pins and remove the whole door. Are there hinges to prevent that?
KlausG
KlausG is offline   Reply With Quote
Old 06-06-2010, 10:47 AM   #2
yes, they have set scews that hold the pins in place and are available at almost all hardware stores
mark2007 is offline   Reply With Quote
The Following User Says Thank You to mark2007 For This Useful Post:
KlausG (06-06-2010)
Old 06-07-2010, 05:45 AM   #3
Exterior hinges usually have non-removable pins, or pins that require a lot of work, and/or special tools to remove.
Old 06-07-2010, 06:14 AM   #4
Rewards Points: 1,514
Drive three or four fat nails (using pilot holes) halfway in up and down the door jamb where the door comes to meet. Cut the heads off leaving about 3/8" (1 cm) protruding. Drill holes to match in the door edge so the nail ends engage the door when the door is closed.
Thanks to my wife, installing a set of French Doors BJLower Remodeling 4 04-04-2010 08:07 PM
Exterior french doors install? imola ghost Carpentry 3 11-16-2009 05:06 AM
Outswing french doors Pooch40 Remodeling 8 05-30-2009 03:47 PM
Replacing Sliders with French Doors ElizaWhyza Remodeling 2 03-31-2009 10:26 PM
French Doors That don't Match! terryb Building & Construction 21 12-17-2007 07:19 PM
