Framing A Window - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-05-2013, 09:47 PM   #1
framing a window
I want to frame a new window opening in my upstairs bedroom.I will be taking out a set of patio doors that lead to a second story deck,framing in a window opening, installing some plywood sheathing, and replacing vinyl siding and interior drywall. If there is already a 75 in opening for the patio doors, do I need to add a header?Is it necessary to get an inspection for any of this work? Thanks, Mark
Mick56 is offline   Reply With Quote
Old 08-06-2013, 06:35 AM   #2
Rewards Points: 13,724
No one knows where you live since you did not add it to your profile, so we'll guess yes on the permit.
There should already be a header in place so, no need to add another one. A couple of 2 X 4's laying flat and a king and jack stud will give you the needed surface area to attach the window and the trim.
http://www.bing.com/images/search?q=...lectedIndex=12
Basic help with window and door rough framing danf26 Building & Construction 3 08-20-2012 10:51 PM
window jambs flush with framing porchhen9 Remodeling 3 05-15-2011 05:42 PM
Rough framing a window hwdruman Building & Construction 4 06-14-2010 09:03 AM
Framing and Trimming Basement Window mjkpainting Carpentry 2 06-28-2009 09:33 AM
Re-sizing a window opening shtoink Carpentry 5 09-04-2008 10:47 AM
