Framing Walls To Concrete Block Basement Walls - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-29-2012, 07:30 PM   #1
byn
framing walls to concrete block basement walls
my basement is concrete block walls...I now want to use wood for framework prior to insulation and sheet rock....how do i attach the wood framing to the blocks
byn is offline   Reply With Quote
Old 02-29-2012, 08:01 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by byn View Post
...how do i attach the wood framing to the blocks?
You don't.
Use rigid insulation (foam) boards against the block...
then set the 2x4wall in front of that attached to the joists above and floor below.
The Following 3 Users Say Thank You to TarheelTerp For This Useful Post:
ben's plumbing (02-29-2012), concretemasonry (02-29-2012), mae-ling (03-01-2012)
Old 02-29-2012, 09:32 PM   #3
Rewards Points: 676
Google "How to frame a basement" and watch a few of the million You Tube vids.
B
Beepster is offline   Reply With Quote
Old 03-01-2012, 01:09 AM   #4
Rewards Points: 2,212
Do a search on this forum for basement insulation.
mae-ling is offline   Reply With Quote
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 07:40 AM
Block basement walls skyline Remodeling 4 01-03-2012 09:10 PM
Framing & Insulating basment concrete walls harddy Building & Construction 8 12-02-2009 12:04 PM
painting basement concrete walls ctkeebler Building & Construction 6 11-17-2009 03:23 PM
removing concrete parging from basement foundation walls. newzev Remodeling 1 07-24-2009 08:17 AM
