Framing A Wall Cubby - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-21-2011, 09:09 AM   #1
Framing a wall cubby
Hello all,
My first post here...love the site FYI:
-My wife and I created a cubby space in a wall that divides our living and dining room. I want to frame out the areas with trim that I bought that is 1 and 3/4" wide.
Problem: One of the cubbies only as 1 and 1/2" space on the right side of it to frame in, so I thought that I would just rip 1/4" off with my table saw.
Real problem: How would I miter the corner of the 1 and 3/4" and the 1 and 1/2" sides at the top of the cubby to make it look clean? (ie the 1 and 3/4" is going to be "taller" but I have to imagine there is an angle I can cut that to make it look clean)
Any thoughts?
jonnyl95 is offline   Reply With Quote
Old 09-22-2011, 07:40 AM   #2
Rewards Points: 5,336
Don't miter the corners, butt them together.
Ron
B. Franklin 1759
Old 09-22-2011, 07:42 AM   #3
Framing Contractor
Rewards Points: 120
I agree if it is flat stock to butt together. If it is not flat, a 45 degree miter still works. The side piece will get the miter first, and then the wider side would be ripped to size.
sixeightten is offline   Reply With Quote
Old 09-22-2011, 07:43 AM   #4
We found a "bed rail" that we liked and I think that butting them together would look a little weird.
I think I found a formula to do it:
tan(a/b)=angle of a
tan(b/a)=angle of b
So i found out that my angles would be close to 60 and 40 degrees.
I'm gonna mess around with some test peices this weekend
Old 09-22-2011, 08:58 AM   #5
Framing Contractor
Rewards Points: 120
tan(a/b)=angle of a
tan(b/a)=angle of b
That wont work
On flat stock it would but on profiles it will not. You will be making them both a 45 angle from the shortest side.
Framing on top of poured concrete wall Mikeymannii2 General DIY Discussions 2 05-08-2011 06:36 AM
Basement wall framing with baseboard heaters gregkfraser Building & Construction 3 11-14-2010 09:35 PM
Non-Load Bearing Wall Window Framing? ericht Building & Construction 28 01-27-2010 08:38 PM
Framing stair knee wall... bparise Carpentry 6 11-14-2009 12:03 AM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
