Framing Out Windows In Basement - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-28-2012, 10:30 AM   #1
Framing Out Windows in Basement
Can anyone explain how to frame out a window in the basement when the interior wall is over a foot off the foundation?
Thanks In Advance
rhymlz is offline   Reply With Quote
Old 04-28-2012, 10:41 AM   #2
Rewards Points: 636
picture please
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 04-28-2012, 02:43 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,332
having the wall that far off the foundatin will create a very deep window box for trim. in that situation i woiuld attach pt wood nailers to around the perimeter of the window opening on the foundation. this will give added nailing for the window box. or if the window is smaller than the opening in the foundation installer nailers around the inside perimeter of the opening
woodworkbykirk is online now   Reply With Quote
Old 04-28-2012, 03:18 PM   #4
Ok so just put the PT wood even with the opening around all four sides and secure into the foundation? Then frame out the opening and trim the gap with wood?
Old 04-28-2012, 04:58 PM   #5
pressure treated must be used when wood is in contact with concrete
Old 04-28-2012, 05:01 PM   #6
Rewards Points: 111
I used PT 1x12 and boxed from the window to the stud wall on mine. I mounted the stud wall so far off the block to hide the SaniPro pipes/water pipes.
dwcopple is offline   Reply With Quote
Old 04-29-2012, 07:34 AM   #7
CrossWorks's Avatar
Rewards Points: 150
  • Can you post pictures?
  • What is the depth from edge of stud wall to window?
  • Take a close-up picture of the space between the window frame and concrete. In most cases that space is 1-4" to 1/2".
Also, if your depth is greater than 11-1/4", then I would revert to Birch plywood. As long as you have enough space around perimeter of window to have 3/4" [birch] plus your PT build out [anywhere from 1/2" to 1" or so].
Building a box with Birch plywood for deeper than normal situation is one of your better options, unless of course you plan to drywall the opening. But remember to get get birch tape for edges.
A great personality will open many doors in life,
but it's your character that keeps them open!
www.crossworksme.com
"Where Every Nail Has a Purpose!"
CrossWorks is offline   Reply With Quote
Old 04-29-2012, 10:13 AM   #8
I'll post pictures on Tuesday.
Old 05-16-2012, 03:52 PM   #9
Sorry it took so long for me to post these
Old 05-16-2012, 04:29 PM   #10
Rewards Points: 2,212
If the wall has to be that far away then do as suggested above, birch plywood is a good idea.
Why is the wall so far away?
mae-ling is offline   Reply With Quote
Old 05-16-2012, 04:38 PM   #11
Sewer line runs above the floor
Old 05-16-2012, 04:39 PM   #12
The only thing is I dont know if I have enough room to put PT on the inside then Birch on top of that.
Old 05-16-2012, 06:18 PM   #13
How high above the floor?
You could box them in on the bottom of the wall then have a narrower wall on top.
If you leave the wall out just use 2x8 or 2x10 to frame around the window, give you something to attach your birch box to.
Old 05-16-2012, 09:29 PM   #14
Rewards Points: 240
that is what i was going to say. make a seating area. or put shelving above the pipes.
Fix'n it is offline   Reply With Quote
Old 05-16-2012, 09:36 PM   #15
I was thinking of using the space for recessed shelving.
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 06:02 PM
Framing a basement ledge nlexi912 Building & Construction 8 11-14-2011 04:24 PM
Pella Windows - Serious Frost Issue snowman72 General DIY Discussions 22 07-08-2011 12:39 AM
Another basement framing thread fbaggins Remodeling 3 07-07-2010 11:48 PM
