Framing Out Basement. Stick Frame Or Firing Strips? - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-10-2010, 09:35 PM   #1
Framing out basement. Stick frame or firing strips?
Hey guys, New to the forum. For three years I built a factory five cobra, this year finished garage and now Im moving to the basement! I have done lots of trimwork in my life but not much framing so I hope you guys are ready for my questions. When framing the exterior walls do most frame 2x4 walls or attach drywall to firing strips? My walls are poured, not block if that matters. My wife hates being cold so keep that in consideration. Thanks!
nickm1024cobra is offline   Reply With Quote
Old 07-10-2010, 09:39 PM   #2
Where are you located ?
Old 07-10-2010, 09:41 PM   #3
Sorry working on my signature now! Chicago suburbs. Yep it gets cold....
Old 07-11-2010, 07:37 AM   #4
Rewards Points: 5,336
Being in Chicago with a cold sensitive wife, you just answered your own question. How much insulation will you get with furring strips? Not too much.
Stud it out with 2x4's or 2x6's.
Ron
Old 07-11-2010, 09:22 AM   #5
thanks Ron,
that is what i figured but being the first go round framing in a basement i didnt know if there was another reason for the fir strips besides saving on cost/time
Old 07-11-2010, 10:54 AM   #6
Rewards Points: 502
I'd do 2x2 strips then get someone to spay in foam insulation before topping it off with drywall. 2" is small enough you can sink a screw right through it into the wall, and leave plenty of beef for the drywall screws to hold on to. I think 2" of the foam will be enough insulation for a basement, and that should help with any posible moisture problems (but get your basement dry first).
another options is just glue up some foam pannel insulation, then strips over it, then an air gap then drywall.
do you have enough headroom down there to raise up the floor a bit?
forresth is offline   Reply With Quote
Old 07-11-2010, 07:09 PM   #7
Rewards Points: 162
I'd stud it up with 2x4s and use R13 fiberglass insulation. Spray foam is nice, but pricy. Leave about 1" of space between the stud wall and the foundation wall just in case you get any moisture. Have fun.
Some advice you receive on the internet can be worth exactly what you paid for it - be careful.
stubborn1 is offline   Reply With Quote
Old 07-11-2010, 09:40 PM   #8
Registered User
Rewards Points: 5,516
Foam board, 2" min.: http://www.buildingscience.com/docum...gs?full_view=1
Sill sealer under p.t. sill plate(capillary and thermal break), no air gap behind wall (convective loop and against Code), air seal rim space and foam board (stop stack effect): http://www.lowes.com/lowes/lkn?actio...248&lpage=none
http://oikos.com/library/insulating_...lls/index.html
Page #4, Fire-blocking every 10’: http://www.codecheck.com/cc/images/CC5thEdSample.pdf
http://www.rd.com/57548/article57548.html
http://www.wag-aic.org/1999/WAG_99_baker.pdf
Be safe, Gary
Old 07-12-2010, 10:21 PM   #9
thanks for the links Gary
Old 07-13-2010, 01:15 PM   #10
Registered User
You are welcome. Any other questions, just ask-- that's why we are here! Any doubt at all, post a picture.....
Be safe, Gary
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 08:50 PM
Nail or glue tack strips in a drain tiled basement? csihde Flooring 15 01-25-2010 11:17 AM
Basement Framing Question Plexus Carpentry 4 01-13-2010 12:05 AM
Can I frame over the builders insulation in the basement? ChaoticBliss Building & Construction 35 11-09-2009 12:19 PM
Framing an unfinished basement captainobvious Building & Construction 7 10-16-2009 09:53 AM
