Framing Basement Window - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-14-2010, 10:04 PM   #1
framing basement window
I am going to replace my wood basement window and would like some advice on the best way to go hd has the vinyl window that instruct you to build a wood frame and lowes has a vinyl window that states you can install into the bare concrete and i have not seen any of the original wood replacements avail does any one have a source for those thank you
ant1929 is offline   Reply With Quote
Old 01-15-2010, 08:40 AM   #2
bump
anyone?
Old 01-15-2010, 09:53 AM   #3
Rewards Points: 346
I would attach the window to the cement using a composite shim for any adjustments. So if the HD window requires a wood frame go with something else. Be sure to fill any gaps with spray foam and be sure to paint the foam or cover it with trim so it is not exposed to sunlight.
Rege
RegeSullivan is offline   Reply With Quote
Old 01-15-2010, 02:53 PM   #4
lowes sells the basement window that can be installed into the concrete i like this idea so i can have a bigger window and more light in my basement
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 07:40 AM
Suggestion for framing around ducts/pipe in basement xuc318 Building & Construction 2 12-19-2009 06:07 AM
Basement Window installation topher0524 Building & Construction 6 10-04-2009 04:46 PM
Basement window brand recommendations. tigereye Building & Construction 1 08-21-2009 06:07 AM
