Framing Basement Window - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-01-2012, 03:19 PM   #1
I'm attempting to frame around my basement window, but the problem is that the sewer line is on the floor. THerefore I have to keep the wall roughly 10 inches from the foundation. My question since I cant put my floor plate next to the foundation wall how do I frame out the window? Any help would be appreciated.
rhymlz is offline   Reply With Quote
Old 04-01-2012, 03:34 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by rhymlz View Post
...the sewer line is on the floor.
...I have to keep the wall roughly 10 inches from the foundation.
Post a couple of pictures.
Old 04-01-2012, 09:29 PM   #3
I think what he's saying is that the sewer line runs along the foundation wall, so the framed wall will be several inches away from the foundation. Which means that the window ledge will be quite deep (over a foot, probably). I actually have the same situation in my basement, and am interested to see how others would handle the situation.
Mohonri is offline   Reply With Quote
Old 04-01-2012, 09:31 PM   #4
Rewards Points: 13,994
Are the lines exposed?
If not how far below the slab are they?
Old 04-01-2012, 11:50 PM   #5
Rewards Points: 2,212
Pics would be a great help.
Is the line actually on the floor or Just above it?
If it is above it enough and you can put a 2x plate under it do so, then build a wall above it hanging from the floor above. Sheet with 1/2" plywood joining the bottom plate on the hanging wall with the bottom plate on the floor, cover with drywall.
Post pics and we can figure something out.
mae-ling is offline   Reply With Quote
Old 04-01-2012, 11:51 PM   #6
Ironlight's Avatar
Usually you build a box opening that extends from the wall back to the window frame.
Ironlight is offline   Reply With Quote
Finishing Basement - Framing with 2x2's mark2741 Building & Construction 13 12-25-2011 07:20 PM
Replacement Window Rough-In Framing Earnie Building & Construction 10 12-18-2011 10:07 AM
Framing a basement ledge nlexi912 Building & Construction 8 11-14-2011 04:24 PM
Basement window replacement topher0524 Building & Construction 7 05-21-2009 02:59 PM
Basement window recessed in foundation Freaka Building & Construction 4 11-09-2008 06:15 PM
