Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 11-07-2010, 08:37 PM   #1
framing basement walls
I am about a 1/3 of the way thru framing the exterior walls of my basement. None of the walls are load bearing. I have some sections of the basement that will be used for storage and I see no reason to stickframe the outer permiter of the storage areas. Any reason I should? I have foam board glued to the foundation walls and will be putting insulation in all walls of living space. Any reason to spend the time and material framing the areas I mentioned earlier? Thanks!
nickm1024cobra is offline   Reply With Quote
Old 11-08-2010, 01:06 AM   #2
Moderator
Most local Codes require covering foam board with drywall or other fire slowing materials, it is toxic when burning (main reason fire-fighters were masks). http://www2.iccsafe.org/cs/committee...E_06_64_07.pdf
Gary
Clothes taking longer to dry?
Insulating poured concrete basement walls Dude Building & Construction 0 03-03-2010 01:24 PM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 05:44 PM
Drylock on basement walls? CooperChloe Building & Construction 2 02-06-2009 10:03 AM
Painting Basement Floor and Foundation Walls meth Painting 5 09-26-2008 08:54 AM
basement walls citimauler General Discussion 1 02-14-2008 08:18 AM
