Framing Basement Walls - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-03-2010, 12:58 PM   #1
Framing basement walls
I am in the process of planning and finishing my basement. When framing can I build a wall directly under the steel support beam?
Also I need to add 2 egress windows in poured concrete. Any advise on this would be greatly appriciated. min. size im told is 3'x5' ?
Dude is offline   Reply With Quote
Old 02-03-2010, 01:52 PM   #2
Remodeling Contractor
2 egress means you need to means to exit the room. One is the window or door and the other is the normal stairwell out of the basement.
Yes you can build a wall under the beam. Use a powder actuated gun with nails made to shoot into the steel to anchor your wall.
basement walls chuckofaltrades Painting 1 10-27-2009 10:51 PM
Need help with very ugly basement walls GrandmaStormy Remodeling 5 03-05-2009 03:43 PM
Drylock on basement walls? CooperChloe Building & Construction 2 02-06-2009 10:03 AM
Painting Basement Floor and Foundation Walls meth Painting 5 09-26-2008 08:54 AM
basement walls citimauler General DIY Discussions 1 02-14-2008 08:18 AM
