Framing Basement Question - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-20-2010, 09:10 AM   #1
Framing Basement question
I was thinkiing of starting to frame by basement and this is a project I would like to tackle on my own. Now let's say I go to frame a wall, I could measure in so many inches from each side of the wall and chalk line it. However, what if my foundation wall is not square. I want my walls to be straight obviously. How to I determine if the foundation wall is square or is there just a simpler way of making the wall square?
markethound80 is offline   Reply With Quote
Old 05-20-2010, 01:34 PM   #2
Not so new
12penny's Avatar
Rewards Points: 520
3, 4, 5...measure out one side of the corner 3' and make a mark, then out the other wall 4' and make a mark. Measure between the marks and you should have 5'. You can also try 6, 8, 10 or larger depending on how much room you have. Dont forget the permits.
12penny is offline   Reply With Quote
Old 05-21-2010, 07:54 AM   #3
You also dont need the framming up against the foundation. I have mine spaced out in areas to make it square. Some were as much as 1".
depending on the city that you live in and how the permit structure works. If they dont look before you start a basement you may be able to get away with some of the work before you pull a permit to gain a little time. For me i had it framed, electrical ran, ducts ran before i pulled the permit. that way i pulled them, had the electrical come out, then i insulated and put up the vb, then had the building inspector come out for the rest. Both passed with flying colors. I did it this way for 1 to get more time, and 2 since i did not finance any of my basement i was able to spread out the cost.
baum is offline   Reply With Quote
Old 05-21-2010, 12:10 PM   #4
Old School
Willie T's Avatar
You've been told about a method that will get you pretty close to square. But for true accuracy, you can't beat pulling a diagonal measurement on what you think is a square.
Here are the dimensions for a 10' square. If you do not have 14' 1-11/16" across the opposite corners, you do not have a square.
Willie T
Framing in basement attached to concrete blocks, how to insulate? drnormie Remodeling 11 01-21-2009 05:40 PM
Finished Basement : Phase 1 : Framing DWilde Building & Construction 5 12-29-2008 01:52 PM
Basement framing insulation question Bcoleman6 Building & Construction 5 03-21-2008 06:37 PM
Basement Framing - Floating Slab JackOfAllTrades Building & Construction 8 02-05-2008 03:20 PM
Framing in a walk-out basement ryanc Building & Construction 2 01-19-2008 10:54 AM
