Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 07-28-2012, 09:57 AM   #1
framing
changing an 18 ft. garage door to a 9 ft. door. how do I go about framing out for it
kensearls is offline   Reply With Quote
Old 07-28-2012, 12:34 PM   #2
In a little over my head
framing
If the existing header can stay, just fill in the other 9 ft with studs 16" OC. Double the last one to support the door trim. Depending how the opening is trimmed, you may need to cut away some 2x6 so the siding will go on. If you can measure accurately you can build your wall laying on the ground, then raise in into position. For such a small opening, it may be easier to build it in place, toenailing the studs to the header. You might consider laying a course or two of blocks under the bottom plate, to get it, and the siding, off the ground. Look at how the rest of the garage is done.
This document has way more info than you need, but the picture you need is in there somewhere:
http://www.awc.org/pdf/wcd1-300.pdf
ratherbefishing is offline   Reply With Quote
The Following 3 Users Say Thank You to ratherbefishing For This Useful Post:
Duckweather (07-29-2012), mae-ling (07-28-2012), tony.g (07-30-2012)
Old 07-31-2012, 08:39 PM   #3
Retired Cabinetmaker
woody4249's Avatar
framing
Are you choosing to do this because of the cost of a 16 ft door?
Think of resale
"I'm not as green as I am cabbage looking"
woody4249 is offline   Reply With Quote
Tiling prior to building kitchen island framing? 444bullett Flooring 8 08-29-2011 10:12 AM
Any opinions on panelized framing? TitaniumVT Building & Construction 5 12-29-2009 02:56 PM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 04:49 PM
Framing Gun - Nail Shank Diameter Questions... MoparAutoworks Building & Construction 5 07-03-2006 10:27 PM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 05:23 PM
