Flooring For A Lousy Basement Floor? - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-05-2007, 08:26 PM   #1
weekend warrior
Rewards Points: 150
flooring for a lousy basement floor?
My basement slab is thin, I don't have an exact measurement but it's from 1958, and I know it's thinner than a standard slab you'd pour today. Anyways...
It's not in great condition. There's no cracks but there is some pitting and parts where the surface is just rough from water over the years.
There seems to be a permanent bit of dampness in the slab. No water ever collects, but it just has large sections of darkness associated with water saturation in about 40% of the basement.
Aside from a new slab, I've seen those raised flooring tiles at home depot. I've heard people talk about them, do they work? They have a sort of plastic frame on the bottom that keeps them 1/2" or so off the gound allowing airflow, and the top is like an osb material. It was $1.50 a sqft I believe. I don't want a finished basement, just a decent floor for my workshop/jam spot.
Any other options or should I just save up for the new slab, which will take at least a year or two
johnny331 is offline   Reply With Quote
Old 06-05-2007, 08:36 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Originally Posted by johnny331 View Post
Aside from a new slab, I've seen those raised flooring tiles at home depot. I've heard people talk about them, do they work? They have a sort of plastic frame on the bottom that keeps them 1/2" or so off the gound allowing airflow, and the top is like an osb material. It was $1.50 a sqft I believe. I don't want a finished basement, just a decent floor for my workshop/jam spot....
You could do that. We like the product (Dricore Flooring). It's not cheap.
LINK: http://www.dricore.com/en/eIndex.aspx
Do your pricing on it. Their website has information on how to calculate the amount of their product that you will need to do an area.
LINK: http://www.dricore.com/en/calculator.aspx
- Build Well -
Old 06-05-2007, 09:30 PM   #3
weekend warrior
Rewards Points: 150
That's the product I was thinking of...
So this will really work for a damp basement, huh?
I'm going to tape a piece of 6-mil down and see how wet it gets, I'll try to post some pictures tomorrow.
Old 06-05-2007, 09:39 PM   #4
FWIW - If you have a ''damp'' basement, the first rule - is to fix the damp issues - before you do any kind of work on it.
- Build Well -
Old 06-05-2007, 09:43 PM   #5
weekend warrior
Rewards Points: 150
well, do I really have any options at this point besides replacing the slab, which I simply can't afford for at least a while.
What about those paint on sealant products, do you recommend any of those?
Old 06-06-2007, 06:04 AM   #6
....What about those paint on sealant products, do you recommend any of those?
There's Drylok:
http://www.ugl.com/drylokMasonry/mas...ofer/latex.php
http://www.ugl.com/drylockFaq.php
Zissner's:
http://www.zinsser.com/product_detail.asp?ProductID=77
http://www.rustoleum.com/product.asp...t_id=696&SBL=5
Other:
http://www.amesresearch.com/basement.htm
- Build Well -
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
Basement flooring choices Brik Building & Construction 23 01-27-2007 02:38 PM
Basement floor reno D.RED Flooring 1 06-21-2006 02:20 PM
Gameroom basement flooring? PaulMcC Remodeling 4 03-09-2006 09:08 AM
Uneven\Buldging Cement Basement Floor SSandecki Flooring 5 12-20-2005 05:06 PM
