#1 |
flooring for attic
This will be at the bottom of my 'to do' list as this new house requires other things first. But I'd like to know if I can forget this or should start picking up wood.
I'm suppose to check the attic access for leaks as there are old water stains according to the Home Inspector. He said there are just rafters to walk on up there. I'd at least like a wood walkway up there from side to side. Will a building supply store have ? plywood in thickness strong enough to walk on? Also with humidity in Florida is this a waste of time as flooring may rot up there? If I bought wood it'd have to be pieces I could get in my little car and carry up those 'pull down' attic stairs. It just sounds hard to have to walk on rafters, carrying a flashlight. |
#2 |
flooring for attic
Get a sheet of 3/4" plywood and rip it down the 12" or 18" and "screw" down,that way you don't run the risk of cracking drywall below.
| The Following User Says Thank You to Ravenworks For This Useful Post: | Startingover (04-29-2012) |
#3 |
flooring for attic
3/4 plywood is a little expensive, but it's what you would want. i'd go 16 or 24 inches instead of as low as 12, but just measure yourself and see what you're comfortable with.
if the plywood starts rotting, then you have serious problems with your house, much more than just replacing 3 sheets of 3/4. |
| The Following User Says Thank You to sevenlol For This Useful Post: | Startingover (04-29-2012) |
#4 |
flooring for attic |
#5 |
flooring for attic
You could always run a 2x12 up therre and screw it down. Splice the joints on a rafter or cantalever and screw in a backing to attach them
| The Following User Says Thank You to masterofall For This Useful Post: | Startingover (04-29-2012) |
#6 |
Moderator
flooring for attic
Good idea to install a permanent rat-run, elevated above the minimum code required R-30 so as not to compress it. Air seal the attic first, wrap/v.b. any HVAC ducting; mastic-seal their joints first, install a housewrap on the new insulation. Best install is 1/2" shim the boards on supporting walls below, add plywood rips (12") with holes throughout for air movement to deter mold from condensation. More important in a heating climate.... skip the holes. Block the new joist ends to prevent over-turning (plywood is fine).
FL is Zone:http://publicecodes.citation.com/ico...001_par001.htm Ceiling: http://publicecodes.citation.com/ico..._11_sec002.htm Find the air leaks from below;http://www.finehomebuilding.com/PDF/Free/021105092.pdf http://www.familyhandyman.com/DIY-Pr...s/Step-By-Step Gary
Clothes taking longer to dry?
Clean the dryer screen in HOT water if using fabric softener sheets. They leave a residue that impedes air-flow, costing you money. Clean the ducting in the last six months? 17,000 dryer fires annually! |
| The Following User Says Thank You to Gary in WA For This Useful Post: | Startingover (04-29-2012) |
#7 | |
Framing Contractor
flooring for atticQuote:
Joe Carola |
| The Following User Says Thank You to Joe Carola For This Useful Post: | Startingover (04-29-2012) |
#8 |
flooring for attic
ravenworks;
rip it down the 12" or 18" and "screw" down. What does this mean? masterofall; You could always run a 2x12 up therre and screw it down. Splice the joints on a rafter or cantalever and screw in a backing to attach them. Not sure what you meant. Except I think you're saying get 2" x 12" boards and lay up there to walk on. GBR in WA; I couldn't do any of those things myself but thanks for the suggestions. Joe: Ok, ceiling joists it is. PS also I don't have any way to cut wood so have to rely on what I can buy 'as is'. Unless the home store cuts it for customers. Last edited by Startingover; 04-29-2012 at 07:25 PM. |
#9 | |
Framing Contractor
Joe Carola |
#10 |
flooring for attic
I was going to hammer a walkway down but I can see an electric screwdriver would be better.
Yes I have a hand saw I just don't like sawing. I could hire a handyman but I prefer doing things myself. It's fun sometimes. I'll ask at the home store if they cut plywood and then buy pieces I can take home in my car and also that way they'll be manageable to take up to the attic. Then I'll screw them in place. Last edited by Startingover; 04-30-2012 at 12:21 AM. |
#11 |
flooring for attic
After reading all the above posts "Startingover" I've come to a few conclusions for you to consider.
A great personality will open many doors in life, but it's your character that keeps them open! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. "Where Every Nail Has a Purpose!" |
| The Following User Says Thank You to CrossWorks For This Useful Post: | Startingover (04-30-2012) |
#12 |
flooring for attic
Crossworks,
would it really hurt that much to compress insulation when it's only the width (which ever width I end up going with) of a walkway? For a small house, 1,430 sf there's a lot of roof pipes and vents and I will be checking those areas for leaks also. The Home Inspector said "after rain" but not sure how often I'll go up there, maybe every few months. The roof is getting old at 12 yrs old. The house has a hip roof and is a shallow U shaped house. I suppose I need to find a handyman. My dad never hired anyone. I just retired so have plenty of time and I'm totally amazed at my girlfriends who can't do anything nor do they want to. I used to work in a city building permit department with 6 inspectors and always had someone to ask for advice. thanks. |
#13 | |
On the otherhand, if it's conventional framing, then in most cases you would have 2x6 ceiling joist and or 2x8 if the ceiling span is an extensive distance. Either way you may have two layers of rolled insulation in place. One in-between joists and another laying in the opposite direction on top of the joist. If either of those situations exist, having anything pressing down on the insulation I would guess is not recommended and may be an issue [which i'm not very familiar with] down the road. In this case; Better to be prudent than uninformed. [no sarcasm there either ] Just saying. My advice in this would be to call Owens Corning direct and get their input. I'm sure they get this question frequently. Good luck.
#14 | |
AHH, SPANS!!!
you might also want to get someone up on your roof to check for and seal leaks. the right person will know exactly where to find the trouble spots on a roof and fix them for you... |
| The Following User Says Thank You to hand drive For This Useful Post: | Startingover (04-30-2012) |
| Display Modes | |
| Lumber Liquidators | Bud Cline | Flooring | 11 | 10-28-2011 03:00 PM |
| asbestos in our ripped up flooring?? | 6fthook | Flooring | 16 | 07-30-2011 12:06 AM |
| DuraFlex Epoxy Flooring Problem | Amon | Flooring | 7 | 07-18-2011 11:19 PM |
| Installing Hardwood Flooring on Concrete Flooring, Condo | slickwilly789 | Flooring | 1 | 10-08-2010 09:53 PM |
| Installing engineered flooring in the Philippines | Flt_Simulation | Flooring | 15 | 07-21-2009 09:00 PM |
