Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 05-19-2011, 11:19 PM   #1
floor and wall gap in remodeling
i am enclosing a carport-the contractor built a subfloor deck and along one wall in one area there is about a 1/8 to 1/4 in gap -where the floor and wall do not meet-i can fit my cats litter box door through it -is that to code -i thought there should be no gap at all?
mrstaylor is offline   Reply With Quote
Old 05-20-2011, 12:26 AM   #2
Is there a baseboard and shoe molding?
____________
Vince
Old 05-20-2011, 08:03 AM   #3
Have him put a few long screws in the area to pull the 2 surfaces together.
Ron
Old 05-21-2011, 03:46 AM   #4
doesn't sound like a big deal, if you want the area finished then it will be covered by the drywall. If no drywall then will be covered by baseboard/quarter round. If you are leaving it rough then it is what it is, a subfloor. To put it in perspective, finish flooring is always a quarter inch short of a wall for expansion, then covered up by moulding. Don't believe any codes are broken in this case.
Remember you are dealing with "rough" framing (although it should still be done to a quality standard) and so you can't always have a "finished" look to it. That is why we lay floors and cover up walls, etc.
Shouldn't give you any problems whatsoever for finishing. I am saying this because you say "in one area along one wall" and that the max is a quarter inch. Doesn't sound like a big deal. Remember it is a subfloor.
chrisBC is offline   Reply With Quote
