-   -   Floor Joist butchered... (http://www.diychatroom.com/f15/floor-joist-butchered-170564/)
jl61190 01-30-2013 10:34 AM
Hi all, really enjoyed the feed back on my first post, so here I am again with another issue. :) The stair well in my home is pretty narrow (less than 3') and has a spot of very low clearance where the second story hall floor cuts across. There have been multiple patch jobs in this area, poorly done... which seems to be a trend within this house :icon_rolleyes: .... Anyways, when I tore out the patch job I found that the 2"X6" joist underneath had been notched to ****. So, now I'm thinking the right thing to do would be to sister another joist to it. Here's my issue: Immediately to the right there is another joist running perpendicular to this one, so the new board would not really extend far (like 6") beyond the notch. Will this be an issue? I suppose that couldn't really make it any worse! The area to the left is open, so I would be able to get the new board to extend fairly far that way...
Also... I would LOVE to get more clearance in the stairwell, but realize it may not be possible... just thought I'd mention it if anyone had any clever ideas that don't involve changing the foot print of the second story. I'm 5'4" on a good day and still have to duck when going up the stairs....
And because pictures are worth a thousand words:
Before:
http://i388.photobucket.com/albums/o...pscc9dd2e8.jpg
Half way through, you can see the original lath/plaster on the top half, and dry wall tacked on below...
http://i388.photobucket.com/albums/o...ps80ad6add.jpg
Notched Joist exposed; the deepest notch reduces the board to 2 1/2". I'm not sure why this was done. Maybe to fit something upstairs?
http://i388.photobucket.com/albums/o...ps65603cf6.jpg
woodworkbykirk 01-30-2013 07:33 PM
sounds like its a really old home.. older homes have much tighter stairwell openings and back at the turn of the century there werent as many tall people walking around.. current code requires 6'8 clearance between nosing and lowest point in the stair well so you dont hit your head
joecaption 01-30-2013 07:48 PM
We've had to go so far as cutting the floor back to make enough head room.
Gary in WA 01-30-2013 08:53 PM
Use a 2x4 laid flat at the headroom side, with a angle cut ripped on the edge. Follow that angle with a doubled 2x4 ceiling joist where it clears the new angle/line, then a doubled 2x? --- 16" away to clear that bottom angle farther back, until a standard joist fills the cavity-- your horizontal/angle starting point. Fasten new drywall, tape/mud/etc.
Gary
