Flash Existing Window - Remodeling - DIY Chatroom Home Improvement Forum
Old 10-07-2013, 07:03 PM   #1
Removed old T-111 siding from the house and am getting ready to install new siding. What is the correct way to reflash the existing window without removing it? Have OSB currently installed and getting ready to wrap the house. Can I use flashing tape around the window?
ToyTun11 is offline   Reply With Quote
Old 10-07-2013, 08:29 PM   #2
Registered User
Rewards Points: 526
Add this head flashing; http://www.mtcc1170.com/images/BCRainScreen.pdfp.8- http://www.mtcc1170.com/images/BCRainScreen.pdf
after jamb flash but before head flash in Step 8 here; http://www.buildingscience.com/docum...researchreport
Leave 1/4" to the flashing/siding for drip edge, smear caulking on cut exposed edge grain of siding above flashing, be sure to over-bend flash for 110*, hold tight to window. No nails through flashing at head.
Gary
General window install questions miamicuse Windows and Doors 9 04-23-2013 08:05 PM
Existing Window Installation Earnie Windows and Doors 15 02-21-2012 01:04 PM
window into an existing wall bamaranch Building & Construction 9 01-21-2012 05:18 PM
Window casing around j channel on existing siding zacharyw Remodeling 9 11-21-2010 08:42 AM
Replacement Aluminium Window - Reusing existing sill flashing? GrantJohnson Building & Construction 4 02-10-2010 10:27 AM
