Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 06-05-2012, 05:31 PM   #1
Fixing a stud problem
I somehow got a bit further than the photo before I realized that I have a hump right in the middle of the wall.(marked) When laying the 4' level horizontally with the center on those two studs, I get a rocking that is about 1/4" on each side. Seems like too much. I think I know the answer - remove the concrete boards and shave down those studs to level out the wall.
Question: Is it then ok to put the board backs up using the same holes or should I be making new ones and just thinset over it all?
What is the best way to remove the stud material? Planer?
thanks in advance for your comments
nickjstocker is offline   Reply With Quote
Old 06-05-2012, 05:37 PM   #2
Planer would be the fastest way.
Always pull a piece of brick string tight againt the studs to check them before installing sheetrock or tile board.
Old 06-05-2012, 05:53 PM   #3
Super Moderator
If it's not an outside wall----take a saw and cut the stud almost all the way through in the middle--
Push it back into plane and sister in a straight stud next to it.
princelake (06-05-2012)
Old 06-05-2012, 06:01 PM   #4
Yes - it is an exterior wall - it is not load bearing though! There are two studs and they now have plumbing passing through them. They seem fairly level at top and bottom so I think I just need to take the crown out. thanks
The Following User Says Thank You to nickjstocker For This Useful Post:
oh'mike (06-05-2012)
Old 06-05-2012, 08:59 PM   #5
AHH, SPANS!!!
maybe pop a chalk line on the side of the stud from the top down to the bottom and use a level and pencil over top of the chalk line to accentuate the line so that you can see it better and use a planer, sawzall,or skilsaw to take out the extra that sticks into the room. popping a line on both sides of the stud will have more accurate results.
hand drive is offline   Reply With Quote
Need Help Fixing Damp Slab Problem in Shop OlyTDI Building & Construction 10 10-30-2011 01:35 AM
Double Bowl Kitchen Sink Drainage Problem PeteW Plumbing 16 09-05-2011 10:41 AM
2 outlets sharing a stud and also telephone jack? LeviDIY Electrical 9 09-02-2009 10:24 AM
Stymied by window leakage problem. Matth3w General Discussion 5 06-11-2008 07:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
