Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 04-22-2011, 12:51 PM   #16
Stuck in the 70's
Blondesense's Avatar
First Major Remodel
Originally Posted by mikeylikesit580 View Post
I am debating on tile and laminate for the flooring. I'm assuming I would want to do the laminate before I put the toilet down and vanity down right? But tile I would want to do that later correct?
Any flooring should go before/under the toilet.
FYI, don't caulk around the base of the toilet, or at the very least leave the back uncaulked. If the wax ring should leak, you want to see the water. You don't want to seal it in so it totally soaks your subfloor and ruins it.
If you go with any sort of laminate or floating floor, cabinet goes in first. With tile, you can go either way although I think most here would tell you to tile first.
Edited to add: If you're getting a new vanity, I'd look into one with legs rather than solid base. It may make dealing with the vent a bit easier.
Old 05-03-2011, 07:34 PM   #17
First Major Remodel
Thanks BlondeSense, I think i am going to start picking stuff up for the project next week and start next month...
mikeylikesit580 is offline   Reply With Quote
Old 06-29-2011, 06:23 AM   #18
First Major Remodel
Originally Posted by Jblood View Post
I think you are very ambitious to think this is a one week job. If you haven't done this type of remodel, I would plan to take your time on it. If you are staying in the house for many years or want to re-sell it in a few years, I would tell you to take more time or plan for it. If the window opening interferes with the shower unit you are installing, I would re-size the window framing to go only above the shower unit and use glass block only. Any window that opens in the shower or tub area could become a problem in the future depending how you keep the water off of it. I would run a smooth pipe,pvc, sheet metal or something similar from your new exhaust vent out to the overhang of your roof and vent it there or directly up through the roof, but this will require more more and flashing issues. Get the largest cfm vent you can to get the moisture out as fast as possible. I have been to many Green Build and Home Improvement shows or seminars and I am learning a lot about moisture control or exhaust. I would be careful about using vapor barrier in this remodel. You may actually cause mold problems in your walls or house that will cost you a lot more in the future. I would go with greenboard for your drywall, standard wall insulation that meets code, and make sure to add extra wall bracing for your desired fixtures, so you can screw all accessories to the wood as opposed to trying to use drywall fasteners. Go slow on this project, especially if you have another shower in the house to use. Get a drawing or layout from your local products dealer and really plan what you want it to look like when you are done. I have worked with plumbers, electricians and general remodelers for many years. You will run into some problems, hopefully small ones and you need to be patient while working through them. Don't cut out something because you want to save time or a little money, do it the right way and get a keg because you'll need more than a few beers if this is your first re-model. Plan for 2-3 weeks of here and there work, this way you stay fresh and don't get to frustrated over certain parts of this remodel. Best of luck!
Hey Guys, Sorry for taking so long to get back to you all! Been really busy with work. I dont plan on getting in done in a week at all. I took a week off work to get the big stuff done, (tear down and rough in stuff) My dad is a carpenter by trade so I am hoping that he can help me!
After looking at your heat vent near floor by the door, if you plan to put in a vanity, you will need to re-work the vent to come out of the bottom of the vanity kick plate area or have it move to another wall. This bathroom is exactly the same layout as my last home. The window is small, if you really want the natural light, put in a block window system that is above the show unit or scrape the window entirely. If the window doesn't open and close properly now, you have some form of water damage and swelling. Be prepaired for more time on this. Good luck, again after I saw some of your pictures.
I am going to have to figure something out with the duct work, Window is newer, but in good shape. I plan on glass blocking it. Let me ask you guys this. If I glass block would you cover it with a insert? I really dont want to cover up a window though. My luck it would get broken or start leaking and I would have no idea.
Originally Posted by tpolk View Post
will take a week just for drywall and paint
Its pretty small I hope I could get drywall done in a day and a half, but it is going to be my first time so well see.
Old 06-29-2011, 06:46 AM   #19
Super Moderator
First Major Remodel
Glass block----I've had the glass block 'made up' at my local brick yard---standard practice around here--for a small fee they mortar the blocks together and wrap it with a steel band---sure beats learning how to be a mason.
Drywall--1 day to hang--and patch/fill---maybe tape---two more coats--,minimum.-2 1/2 days.
Old 06-29-2011, 07:36 AM   #20
First Major Remodel
That's a great idea! Never even thought about having them to that. Thanks mike. I'm debating using greenboard in the entire bathroom, being that the bath is only 5x8ish haha!
Old 06-29-2011, 09:01 PM   #21
Super Moderator
First Major Remodel
It's not necessary,but the added cost is tiny,so ,why not?
Old 07-07-2011, 06:44 AM   #22
First Major Remodel
Thats my thinking, going overkill never killed anybody right? but why do they call it overkill then????
So the planning is still going strong. Made another decision. The Window is going. I am going to remove the window. Replace with plywood and pay somebody to put some new siding there. I can also they run my vent our the side of the house then instead of cutting a while in the roof!
Old 07-13-2011, 06:17 AM   #23
First Major Remodel
Another road block:
Do I need an above tub drain? I see that is an option on all the kohler tubs. I imagine that just puts the trap above the floor right? I would assume my tub being so old probably has a below tub drian?
Old 07-13-2011, 07:02 AM   #24
Super Moderator
First Major Remodel
Another road block:
Are you talking about an over flow ???
You don't have a choice ,if that's what you are referring to---they all have them now.(and have had them for the last 50 years)
Old 07-14-2011, 06:09 AM   #25
First Major Remodel
Hey Mike,
I really am not sure what I am thinking. I guess I was thinking like a toilet with the PTRAP built into the tub. but that doesn't make much sense now does it.....
I am going to do further inspection later today after work but it appears that I do have a PVC going upstairs. Going to start opening up the back of the wall with all the plumbing in it to see what I have to deal with in there.
Thanks again for all the help guys, I will keep you updated as the project progresses.
Old 07-28-2011, 12:53 AM   #26
First Major Remodel
My first project is my bathroom... I am not doing the actual work as I am not handy... but the info here helps me know the right way to do things and choose the right people...and to plan so that everything gets done in an orderly fashion... including the septic system and all the waste pipes (as long as the walls are open)... plus coordinate that with the attic insulation (as long as the ceiling is open)...and with the kitchen piping
javagirl500 is offline   Reply With Quote
