Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 12-24-2011, 06:11 PM   #1
Lake Forest, CA
Fireplace surround remodel.. Need some options/advice
Howdy folks,
I am in the process of remodeling my fireplace surround. I had envisioned a tile surround and "hearth" with a pillaster and mantle bordering the tile. After getting the old stone and mantle off I find that I have some challenges to deal with.. The lentil and the firebox brick are not flush with the drywall so simply tiling is not going to happen like I hoped. I am looking for some options to deal with the uneven surface and still get the look I want.
I think I may have to build up some brick to create an even surface and then tile over it which will box out the tile a bit.
Any other ideas?
Cheers,
SKINNY
SKINNY is offline   Reply With Quote
Old 01-06-2012, 11:46 PM   #2
Do you know what is behind the brick?
I ended up taking all of my brick out and attaching cement board to the studs. It might give you a more level and stronger surface to adhere the tile to.
Rotate is offline   Reply With Quote
Old 01-08-2012, 03:19 AM   #3
Lake Forest, CA
I think I am going to end up furring out some hardie backer board so that the tile clears or mates up to the edge of the firebrick.. I'll just use thinset or mortar to fill any uneven gaps.. I'm really not looking forward to attaching the furring strips to the brick.. Maybe I'll get lucky and it will go easy.
Fireplace remodel CHINITAM Building & Construction 1 01-29-2011 12:06 AM
Access Door Panels For Tiled Fireplace Surround Fire4Effect Tiling, ceramics, marble 0 09-07-2010 02:12 PM
Need some help with Fireplace base and surround bowanna03 Carpentry 4 03-14-2010 05:37 PM
Fireplace remodel -- need advise & suggestions mwehnes Building & Construction 12 06-28-2009 10:36 PM
Fireplace Surround Remodel baksdak Project Showcase 5 03-06-2008 01:28 PM
