Fireplace Replacement - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-12-2010, 08:48 AM   #1
I Try
Hi all,
I am removing my free standing fireplace and replacing it with a wood stove. Is there any concerns with the chimney I need to know about? Attached are some photos of the fireplace and firestop.
remernorth is offline   Reply With Quote
Old 06-18-2010, 09:24 PM   #2
I Try
Hello
No one has any advice for me?
Old 06-19-2010, 11:09 AM   #3
Civil Engineer
Rewards Points: 4,700
I do not know the rules for Michigan. When I installed a fireplace insert (basically a wood stove) in my fireplace, I need a chimney liner installed, which was a double wall stainless steel liner. You have what looks like a galvanized riser in your house, I assume it goes through the roof. Around here, such a riser would need to be double wall, and there are specific clearances above the roof line. Normally I leave that to the installer, but if you are doing your own install, perhaps the company that sells you the stove knows the regulations.
As a last resort, you might want to talk to the local building inspector, especially if you are pulling a permit. That might know their own rules.
Daniel Holzman is online now   Reply With Quote
The Following User Says Thank You to Daniel Holzman For This Useful Post:
remernorth (06-19-2010)
Old 06-22-2010, 11:40 AM   #4
If you're looking for specialty remodeling projects like fixing your fireplace, you could start by checking out professionals like RSU Contractors. They've got examples of custom built fireplaces and other home remodeling projects on their website.
billing is offline   Reply With Quote
Fireplace blower - motor replacement kelley4180 Remodeling 3 12-20-2009 06:38 AM
new opening in fireplace? burningbaal Remodeling 3 10-11-2009 01:18 PM
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 06:12 PM
convert wood fireplace to gas fireplace brisk Building & Construction 3 06-19-2008 08:17 AM
Possible to build direct-vent fireplace? DIYerself General DIY Discussions 3 12-22-2007 10:07 PM
