Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 12-04-2012, 10:10 AM   #1
dvmbound1977's Avatar
Fireplace Remodel - See Pics
I need to raise the base of the hearth to accomodate my 2cm granite slab. It is about 3.5 inches here now. I hesitate to use wood due to expansion and code regulations. There was sand in this subspace previously. I of course need to make it level before I measure and put in granite.
Once I figure out support underneath, I plan to add hardibacker, thinset and then granite.
The heat from the fire is not a concern since the new vented gas won't get near as hot as a wood burning fireplace, however we left the fireplace so that it could be converted back for any future owners.
Thanks for any help.
Fireplace Remodel - See Pics-2012-12-04-07.46.29.jpg   Fireplace Remodel - See Pics-2012-12-04-07.46.46.jpg
dvmbound1977 is offline   Reply With Quote
Old 12-04-2012, 11:40 AM   #2
STAFF
BigJim's Avatar
Once you have the support you need just mud it in and level it out good then install.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is offline   Reply With Quote
Old 12-04-2012, 12:54 PM   #3
Is a wood base okay to support or should I use sand?
Old 12-04-2012, 10:22 PM   #4
STAFF
BigJim's Avatar
If you use wood be sure to hold it back from the fire box a little. I have see people build right up to the fire box and the house caught fire from the edge of the hearth getting so hot. I know you aren't going to burn wood but someone on down the road might.
You could build within 6 inches or so of the fire box with wood and then use something fire proof the rest of the way. I personally wouldn't use sand as a base because something dropped could cause a crack. JMHO
Jim
The Following User Says Thank You to BigJim For This Useful Post:
dvmbound1977 (12-06-2012)
Old 12-06-2012, 12:13 PM   #5
I am not in favor of the sand either. I could easily allow for 6 inches around the firebox. Any suggestions for support in that space.
Old 12-06-2012, 10:48 PM   #6
STAFF
BigJim's Avatar
If it were mine I would build up with wood except for the area at the edge of the fire box, I would build up a mud base to the height of the wood, install a backer board over the wood and mud then make the install.
Jim
dvmbound1977 (12-17-2012)
DIY fireplace remodel gone awry - impenetrable brick wall shawnad73 Building & Construction 8 08-23-2010 09:52 AM
[Pics Inside] Unsure what this part does (electrical fireplace switch) rdiggidy Electrical 4 09-07-2009 07:14 PM
Fireplace Remodel - Insulation around chimney GeauxCajuns82 Building & Construction 3 01-19-2009 05:30 PM
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 07:12 PM
Help with an old fireplace remodel Atomikk Building & Construction 3 10-15-2008 03:44 PM
