Fireplace Remodel - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-09-2011, 06:46 PM   #1
Fireplace remodel
So, I searched other posts and can't seem to find what I need... I'm gearing up to remodel my fireplace. It's going to be dry stack stone veneer floor to ceiling. I've got the nuts and bolts of that pretty much figured out, except for one thing: Mounting the mantel. The stone is of varying depth, so I don't think mounting it to the finished stone is a good option, although I could be wrong. So, do I mount it to the scratch coat and add stone around it (the stone is only about 2-2.5 inches deep)? Attach it straight to the cement board backer, then add lath, scratch coat and stone around that? My person vote is after the lath and scratch coat, but I'd really like some input. Thanks in advance for any help!!
cfurball is offline   Reply With Quote
Old 04-09-2011, 09:09 PM   #2
Jack of all trades
danrb007's Avatar
Send a message via Yahoo to danrb007
I like the idea of stoning around it. you could also mount some steel to the wall behind and have it stick out to mount the mantel to then make a template out of cardboard to cut the back side of the mantel to match the stone.
danrb007 is offline   Reply With Quote
Old 04-10-2011, 08:17 AM   #3
Rewards Points: 5,336
The simplest method would be to attach it to cleats mounted to the wall and stone around it. You want it mounted to an even surface, not a scratch coat bumpy surface.
Ron
Old 04-10-2011, 10:12 AM   #4
Concrete & Masonry
Rewards Points: 470
Ron, as usual, is exactly right. Mount it directly to the studs, or drywall. Cut the lath/Durock around it. If you're concerned about loosing the 2-2.5" of depth to the finished stone, you can add rough construction lumber behind the mantel to pad it out.
Make sure the mantel is finished BEFORE you install the stone. Get it stained and varnished before hand, because moisture from any mortar in contact with it will wick into the wood & create future finish problems.
jomama45 is offline   Reply With Quote
Fireplace remodel CHINITAM Building & Construction 1 01-29-2011 12:06 AM
Fireplace remodel -- need advise & suggestions mwehnes Building & Construction 12 06-28-2009 10:36 PM
Fireplace Remodel - Insulation around chimney GeauxCajuns82 Building & Construction 3 01-19-2009 05:30 PM
Help with an old fireplace remodel Atomikk Building & Construction 3 10-15-2008 03:44 PM
Fireplace Surround Remodel baksdak Project Showcase 5 03-06-2008 01:28 PM
