Fireplace Mantle - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-16-2010, 08:21 AM   #1
fireplace mantle
gas fireplace needs a new mantle. planning a wood mantle (Poplar) and surround to be painted. Concern is limited space:- (approx. 4-5" on either side of the metal gas fireplace insert built into the wall.) All I have ever seen has a marble, granite, etc. spacer around the insert, then the wood mantle. Could I substitute Hardeboard for this, and paint it to match the wood? I'm assuming the Hardeboard would serve the same purpose as the Stone slabs I've seen around the gas fireplace insert and would meet code for fire prevention. There's drywall butting the insert now.....
Thanks for any advice you can give.
MKGBC is offline   Reply With Quote
Old 08-16-2010, 11:06 AM   #2
Rewards Points: 558
You should have no problem with that.
epson is offline   Reply With Quote
Old 08-26-2010, 11:38 PM   #3
Hardiboard being cementious is fire retardant though not fire proof.
gjjr2001 is offline   Reply With Quote
Painting over an oak fireplace mantle kitlin Interior Decorating 0 04-25-2010 07:38 AM
Fireplace Mantle golf22 Carpentry 3 12-28-2009 05:29 PM
fireplace mantle and trim board connieriv Interior Decorating 3 01-04-2009 10:33 AM
Fireplace Mantle need help with color and technique Staticman2 Interior Decorating 4 12-11-2008 02:05 PM
Question about wood mantle on stone fireplace Daggerhart Remodeling 2 06-15-2008 04:16 PM
