Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 09-19-2009, 11:02 AM   #1
Fireplace headache
Hi, am new to this, pls bear with me.
I have a fireplace with hearth, but there is no surround or mantle. I have been told that the wall is empty...only studs are at each side so putting up a mantle will not work. I guess what i am wondering is...can i put a large piece of plywood on wall, secure to studs and go from there? Also wondering if i can put tile over some of the black metal surround around the doors of the fireplace? Or if i can put the tiles directly on the plywood...but have the plywood cover some of the metal? Sory if this sounds confusing.
dcdahlin is offline   Reply With Quote
Old 09-19-2009, 11:19 AM   #2
the Musigician
DangerMouse's Avatar
Fireplace headache
Hi and welcome to the forum.
If you could post some pictures, it will help.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 09-19-2009, 11:40 AM   #3
Fireplace headache
Here is a picture of the fireplace. What I would like to do is put plywood around, then tile over the plywood.
Old 09-19-2009, 12:52 PM   #4
Drywall contractor
Fireplace headache
You would want to use tile backer, not plywood. There SHOULD be studs on 16" centers including in the center of the fireplace. You can use thinset and screws to hold the tile backer up, then tile...
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 09-19-2009, 02:28 PM   #5
Fireplace headache
Does anyone know if I can cover the majority of black metal with the tile backer or do i have to leave it exposed?
Old 09-19-2009, 03:03 PM   #6
the Musigician
Fireplace headache
I see no reason to leave any of it exposed.
DM
Old 09-19-2009, 03:29 PM   #7
Drywall contractor
Fireplace headache
You can cover it.
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 07:12 PM
convert wood fireplace to gas fireplace brisk Building & Construction 3 06-19-2008 09:17 AM
temper glass for fireplace mantel shelf sil Interior Decorating 3 02-13-2008 09:10 PM
Possible to build direct-vent fireplace? DIYerself General Discussion 3 12-22-2007 11:07 PM
