Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 10-03-2010, 07:35 PM   #1
Fireplace granite surround, what adhesive?
Hi there-
I put in a fireplace insert, and am going to surround it with 3/4" granite. I cut out 8 inches of sheetrock to the left and right of the insert and replaced it with 1/2" plywood. 1 inch of the granite will overlap the metal face of the insert on left and right, the remainder will be on the plywood. The top will have 6 inches on the metal and 6 inches on plywood (the metal face on the insert is much taller on top than the sides).
The granite will be in 4 pieces, a bottom piece, two sides and the top...so they'll sit on top of each other. I'm trying to decide what kind of adhesive to use that will adhere granite to both the metal and the wood. I'm not sure if the fireplace will get hot on the face, it's new and I haven't used it yet...so I don't know if heat needs to be a consideration for the adhesive.
Epoxy? Silicone? A liquid nail product?
Any advice would be greatly appreciated.
Thanks,
Brent
Charlotte, NC
bsmith6356 is offline   Reply With Quote
Tags
adhesive, fireplace, granite
Access Door Panels For Tiled Fireplace Surround Fire4Effect Tiling, ceramics, marble 0 09-07-2010 02:12 PM
Need some help with Fireplace base and surround bowanna03 Carpentry 4 03-14-2010 05:37 PM
Removing Granite & Omni Grip Adhesive from Fireplace Surround RayJak Tiling, ceramics, marble 4 11-13-2009 04:28 PM
Granite & Adhesive question cody21 Kitchen & Bath Remodeling 3 07-22-2009 06:11 PM
Stonemark & Silestone Countertops......??? DepotDweller Remodeling 9 06-25-2009 12:44 PM
