Fireplace Facelift - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-13-2007, 02:42 AM   #1
Question
fireplace facelift
We've got a fireplace in our newly aquired home (circa 1939). The decorative plywood surround has been severely damaged, and removed. Thus leaving the old, ugly, unevenly spaced brick exposed. We have quite a bit of 12" slate tile leftover from our kitchen floor remodel, and thought that it might look good to cover the old brick. The tiles are 1/2"-3/4" thick, and are cut smoth on one side and left rough on the other. We'd like to place them rough side out, on an angle (in a diamond configuration).
Right now we can't afford to "have this done profesionally", and I have done tile before... but only horizontaly (never on a wall). I'm not sure what to use to adhere the slate to the brick. Mortar, thinset, mastic, liquid nails, chewing gum? What would you suggest?
Thanks in advance!
Erebus
Erebus is offline   Reply With Quote
Old 05-14-2007, 04:58 PM   #2
Rewards Points: 1,488
Well...
All those things you cited would work, except maybe the chewing gum...
Me, I would use a ceramic tile mastic.
ktkelly is online now   Reply With Quote
convert wood fireplace to gas fireplace brisk Building & Construction 3 06-19-2008 08:17 AM
huge fireplace issues krynstar Painting 10 03-10-2007 06:41 PM
Fireplace leaking mmcginn2 Roofing/Siding 4 04-23-2006 10:12 AM
Water leaking over fireplace mmcginn2 General DIY Discussions 1 04-20-2006 11:42 PM
A facelift for your home Grumpy Remodeling 0 07-07-2004 07:43 PM
