Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 12-05-2009, 03:29 PM   #1
Fireplace blower - motor replacement
My fireplace blower/fan sounds like a '78 AMC Concord.
I figured I'd replace the motor. However, I don't have a manual and can't figure out how to get to it.
1.) Anybody recognize the model pictured here?
2.) regardless of question 1, any advice on how these typically provide access to the motor? I pulled the bolts along the bottom, which doesn't seem to do anything.
3.) Finally, is it worth putting a new motor into what appears to be a 15+ year old fireplace fan? Or is newer stuff much better and worth replacing the whole thing?
Input appreciated. Thanks!
kelley4180 is offline   Reply With Quote
Old 12-06-2009, 11:10 AM   #2
Tileguy
Bud Cline's Avatar
The blower should be located under the firebox off to one side. The lower front cover is removable ordinarily but I see some genius has mortared the cover in place. Remove the bolts and chisel the mortar on both ends and see if the cover comes out then.
You should be able to find a replacement blower motor without issue. Fifteen years is not that old if the metal isn't burned up.
Old 12-19-2009, 12:38 PM   #3
Hey thats exactly looks like my fireplace i have been looking for a blower I know its a majestic but the paper on mine is messed up did you ever find one blower should have a number on top
mdr6140@windstr is offline   Reply With Quote
Old 12-20-2009, 07:38 AM   #4
Kelly contact me at mdr6140 windstream.net let me know if you found you a blower
Carrier 58MXA Wiring Blower Switch 63012753 HVAC 0 10-06-2009 10:09 PM
Can I disconnect a gas fireplace blower? davidm Electrical 2 10-03-2009 09:58 AM
Installing Dimmer for fireplace blower MountainMan HVAC 4 07-03-2008 12:09 AM
Possible to build direct-vent fireplace? DIYerself General Discussion 3 12-22-2007 11:07 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
