Fire Stop - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-03-2009, 12:59 AM   #1
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
Fire Stop
I have areas that I know I need to add fire stop in, like where conduit runs between floors, or drops down through rock into sofit boxes to feed lights. I have used some great stuff, but know it isn't a fire stop material and will burn.
Can I use traditional plaster as a fire stop? When you use it on your walls, I know it qualifies as a fire stop material. It sure as heck doesn't burn.
Jamie
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Old 03-03-2009, 06:15 AM   #2
the Musigician
DangerMouse's Avatar
hey jamie... just go buy a tube or two of fireblocking caulk. lots easier to squirt in the holes. Po)
DM
Old 03-03-2009, 08:17 AM   #3
Remodeling Contractor
plaster must be finished which tightens and strengthens the surface, which makes it somewhat fire resistant. Placing in a hole will not be sufficient. Use rated materials only. like blocking, fire caulk, fire rated great stuff (orange), wool fibers, fire blocking mortar, 5/8" sheet rock The fire blocking is used to seal air flow inside a chase. It also must be rated to last 25 plus years.
Old 03-03-2009, 08:34 AM   #4
the Musigician
side note, i'm using 3M's FB 136 caulking. Po)
DM
Old 03-03-2009, 09:22 AM   #5
Rewards Points: 16
jamie, not sure if you've seen it or not but the kctermite has a good how to on fireblocking in the how to site that has some info on what materials to use where.
ponch37300 is offline   Reply With Quote
Old 03-03-2009, 12:06 PM   #6
DIY'er
jamiedolan's Avatar
Do you know where this is? I'd like to read it.
Jamie
Old 03-03-2009, 12:08 PM   #7
DIY'er
jamiedolan's Avatar
DM
I have some areas like where lots of tubes of smurf penetrate through the plaster ceiling (which will be built into sofit boxes). I was thinking about plastering right up to. I think I would use alot of tubes of fire stop caulk just around these ENT tubes.
Jamie
Old 03-03-2009, 12:39 PM   #8
Newbie Bill
Rewards Points: 520
Here is it.
How to fireblock framing
drtbk4ever is offline   Reply With Quote
SCARY oven fire! Why did it burn? Beth777 Appliances 73 09-03-2016 03:19 PM
Ruud Furnace Won't Fire jasonckcmo HVAC 26 12-01-2009 08:55 PM
why wouldn't circuit breaker prevent fire? fauer Electrical 26 11-28-2008 09:38 PM
Hinge door stop fred2007 General DIY Discussions 3 11-11-2007 08:00 PM
