-   -   Fire Stop (http://www.diychatroom.com/f15/fire-stop-39539/)
jamiedolan 03-02-2009 11:59 PM
Fire Stop
I have areas that I know I need to add fire stop in, like where conduit runs between floors, or drops down through rock into sofit boxes to feed lights. I have used some great stuff, but know it isn't a fire stop material and will burn.
Can I use traditional plaster as a fire stop? When you use it on your walls, I know it qualifies as a fire stop material. It sure as heck doesn't burn.
Jamie
DangerMouse 03-03-2009 05:15 AM
hey jamie... just go buy a tube or two of fireblocking caulk. lots easier to squirt in the holes. Po)
DM
Bob Mariani 03-03-2009 07:17 AM
plaster must be finished which tightens and strengthens the surface, which makes it somewhat fire resistant. Placing in a hole will not be sufficient. Use rated materials only. like blocking, fire caulk, fire rated great stuff (orange), wool fibers, fire blocking mortar, 5/8" sheet rock The fire blocking is used to seal air flow inside a chase. It also must be rated to last 25 plus years.
DangerMouse 03-03-2009 07:34 AM
side note, i'm using 3M's FB 136 caulking. Po)
DM
ponch37300 03-03-2009 08:22 AM
jamie, not sure if you've seen it or not but the kctermite has a good how to on fireblocking in the how to site that has some info on what materials to use where.
jamiedolan 03-03-2009 11:06 AM
Do you know where this is? I'd like to read it.
Jamie
jamiedolan 03-03-2009 11:08 AM
DM
I have some areas like where lots of tubes of smurf penetrate through the plaster ceiling (which will be built into sofit boxes). I was thinking about plastering right up to. I think I would use alot of tubes of fire stop caulk just around these ENT tubes.
Jamie
drtbk4ever 03-03-2009 11:39 AM
Here is it.
http://www.diychatroom.com/f98/how-f...framing-37190/
