Finishing Vinyl/aluminum Trim Work - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-22-2012, 04:06 PM   #1
Finishing vinyl/aluminum trim work
I have 3 different projects that the previous owner wasn't able to finish and need some suggestions/ideas.
1. The bay window needs to be finished on the bottom. The footer board is exposed. The height of the exposed wall is 4".
2. It seems like the previous owner wanted to make the sliding glass doors stand out. The distance between the doors and white aluminum trim is roughly 11". The height between the doors and the top is 28".
3. Is this a pediment? I'm not sure what the thought was here. The white trim is aluminum and the edge sits flush to the wall. H 34 1/4", W 19 3/4". (This is on a garage that faces the road.)
I do have plenty of leftover yellow vinyl siding that I can use if needed. Thanks for any and all comments.
Washkin is offline   Reply With Quote
Hardwood Flooring install around this trim? Cmudr1 Flooring 4 01-31-2013 10:29 PM
Advice for installing duct work for finishing basement captainj98 HVAC 1 05-11-2011 07:01 PM
trim work fredogg Carpentry 4 01-07-2010 10:32 AM
oil vs latex for trim work NoExperience Painting 7 08-31-2008 03:42 AM
Interior Door Trim (am I the only one that does this?) javan Carpentry 17 08-14-2008 03:19 PM
