Finishing My Basement - Project Sequence? - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-20-2010, 04:10 PM   #1
Rewards Points: 16
Finishing my basement - project sequence?
Hi
I'm starting to finish my basement and I'm not sure what the correct "order" is to complete each task. I've done some research and most sites have this sequence:
  • Moisture proof walls and floors
  • Install subfloor
  • Lay out your walls
  • Frame walls, rooms and ceiling
  • Rough in electrical, plumbing, cable, and telecom
  • Have electrical and plumbing inspections
  • Install insulation and vapour barrier
  • Install drywall, sand and tape it, prime it
  • Install flooring
  • Install trim and baseboards
  • Install light fixtures
  • Paint the walls
I'm just looking for some confirmation/comments/suggestions on this outline.
thanks
mj
maljeff is offline   Reply With Quote
Old 09-20-2010, 07:41 PM   #2
DIY staff
Rewards Points: 7,174
The one odd ball you have there is "add subfloor"---What is that?
Old 09-27-2010, 08:41 PM   #3
Rewards Points: 4,578
moisture proof walls and floors - the absolute MOST important step,,, what type of foundation wall ? block OR conc ? install vapor barrier on floor ? subfloor on p/t sleepers ?
Old 09-27-2010, 09:23 PM   #4
jlhaslip's Avatar
Rewards Points: 1,440
Some installers prefer the baseboards in place for carpeted area before they install.
Also, stipple the ceilings, prime the drywall, apply first colour coat before the flooring in case there are any Oops! moments.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Basement Project - Grafton, MA cfsully Building & Construction 20 06-07-2012 02:56 PM
Finishing basement, had a few questions about ductwork... Wyjeep Plumbing 12 04-27-2010 09:27 PM
Basement Wall Project flati General DIY Discussions 16 01-04-2010 09:26 AM
Newbie thinking about finishing his basement dewilliams07 Introductions 3 09-11-2009 12:59 PM
finishing a basement jimmyfloyd Building & Construction 2 10-21-2008 12:30 PM
