Finishing Bonus Room - Bowed 2 X4s - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-12-2010, 10:08 PM   #1
finishing bonus room - bowed 2 x4s
i have a few bowed 2 x4s in an existing wall and the back side of the wall has finished drywall. i also have 1 bowed 2x4 that has a plumbing pipe running through it. the 2x4 bow outward towards teh wall i need to hang drywall. is planing the 2x4 the best method to straigten them out?
mikeluvs2build is offline   Reply With Quote
Old 02-12-2010, 10:39 PM   #2
jlhaslip's Avatar
Rewards Points: 2,162
make a cut on the inside of the stud about half way through and use a shim to fill the cut as you pull the stud plumb.
sister a piece beside the cut to maintain the stud's position
cut on the inside of the 'c' shape
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 02-13-2010, 08:45 AM   #3
Old School
Willie T's Avatar
This will work for studs bowed in either direction, in or out.
finishing bonus room - bowed 2 x4s-straighten-studs-1.jpg   finishing bonus room - bowed 2 x4s-straighten-studs-2.jpg
Willie T
Old 02-14-2010, 10:43 AM   #4
That technique will work, but are the studs tough to get out? I assume the drywall on the other side is attached to them? If they aren't too hard to get out you could cut them out and insert a new stud toenailed.
TANC is offline   Reply With Quote
Old 02-14-2010, 12:22 PM   #5
Rewards Points: 502
I would just sister new 2x4s to the existing wall to get a plumb surface.
Otherwise, you risk causing damage to the drywall on the opposite side...cracks, pulled nails/screws, etc.
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 02-15-2010, 08:03 AM   #6
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Why not simply cut the stud nails, and replace the studs?
Sometimes, that is the most efficient method.
- Build Well -
Old 02-15-2010, 08:21 AM   #7
Chaos Engineer
Big N8's Avatar
Rewards Points: 152
What he said^^^^^^^
Big N8 is offline   Reply With Quote
Old 02-19-2010, 09:29 PM   #8
Got a power planer? You could plumb in a new stub then plane down the old stud flush with the new. Might seem like a lot of work, but you would save the drywall on the other side if that was a concern to pulling it completely out.
mgarfield is offline   Reply With Quote
Old 02-19-2010, 09:39 PM   #9
So when you cut them you risk possibly pushing the screw head out and damaging the drywall. the method shown above is the best way to not risk that.
wnabcptrNH is offline   Reply With Quote
Old 02-19-2010, 09:43 PM   #10
I'm with mgarfield on this. Plane it down (power). Will not distrub what is attached to the other side. In fact there are a few drywall companies in my area that come in and plane or shim prior to drywall.
Work is for those who can not fish.
Mop in Hand is offline   Reply With Quote
Japanese tea room itakitez General DIY Discussions 5 06-30-2009 02:23 AM
Furring Rafter in Bonus Room joneseyt Building & Construction 1 06-22-2009 08:48 AM
Should I put 2x6 or 2x10 above garage if I plan to finish the room in the future? rockne Building & Construction 35 06-08-2009 09:33 PM
Questions for experts. Tech08 HVAC 9 01-25-2009 12:47 PM
Laundry Room Dimension Question jonathan03 Appliances 1 01-17-2009 10:08 AM
