Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 12-17-2012, 06:40 PM   #1
Finishing Basement Stairs
All,
Finally getting around to addressing this, but looking for some ideas on how to build a rail and trim this out. The end result is that I want these carpeted, but otherwise open to ideas. The issue I'm having is that I don't want to lose much width because it is a narrow staircase, so not sure where to go from here. Any suggestions? Pictures attached, single landing at the end that then turns into the basement. Also, on the "wall side" I'll be putting in a skirt board for trim, but don't want to do that until it is in the same theme as what I'm doing on the open side.
Finishing Basement Stairs-img_0020.jpg   Finishing Basement Stairs-img_0021.jpg   Finishing Basement Stairs-img_0022.jpg
Shaotzu is offline   Reply With Quote
Old 12-17-2012, 06:52 PM   #2
something like this?
epson is offline   Reply With Quote
The Following User Says Thank You to epson For This Useful Post:
Shaotzu (12-17-2012)
Old 12-17-2012, 06:56 PM   #3
Thanks for the idea, but the question I have is it seems that this involves building the wall down further, or trimming over top of the stairs, or something, and I'm not quite sure how to proceed, especially to create a board for the ballusters to sit on that isn't that stairs . . . Any advice?
Old 12-17-2012, 06:58 PM   #4
STAFF
BigJim's Avatar
I would suggest building the open side, out, and installing this type of rail. You could install a post on the landing to kill the build out and have a place for the rail to fasten the rest of the way down.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is offline   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
Old 12-17-2012, 07:01 PM   #5
STAFF
BigJim's Avatar
Man I am slow, no you wouldn't have to build a wall below, just add onto the side of the stringer and build it up like in the picture.
Jim
Old 12-17-2012, 09:48 PM   #6
Yeah, actually I caught that. Just curious, the wood for the stairs is framed underneath and has drywall attached to it. The ceiling and the outer edge of the stairs are on the same plane. Any suggestions on building it out to create a place for the balusters? I was thinking a 1 by something above the drywall, but that wouldn't give me much to attach to for the railing. So thinking maybe something thicker plus some finish trim, and then attach a 1x2 on the top to provide something for the balusters?
Old 12-17-2012, 10:47 PM   #7
STAFF
BigJim's Avatar
This is just a suggestion of one way to do this. I would build the thickness of a 2X4 wall. If you wanted to you could install your 1X12 skirt board flush with the bottom of the stringer. Next install a 2X12 flush with the top of the stringer, then install a 1/2 inch spacer such as 1/2 inch plywood. Next install another 2X12 flush with the top of the other one. Next install the outside skirt board flush with the top of the 2X12.
Install a 1X4 on top of the 2X12s so it sits inside the skirts and just covers the two 2X12s. You can install a cove mold on the top edges of the skirts tight against the 1X4. On the bottom install sheet rock out to the outside edge of the outer 2X12, not the outside of the skirt. You can finish the outside edge of the sheet rock with a 1/2 inch mold. Or you can install a 1X tight against the sheet rock and finish off with a small mold.
Another way to cap the build is install a 1X6 and center the 1X6 letting the edges over hang a little on each side of the skirts. I like the last cap better but that is JMHO.
From there you cap the end of the build at the landing install your post, the plowed filet shoe and go on from there.
Jim
Shaotzu (12-18-2012)
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 04:11 PM
Outside basement stairs, bulkhead stairs, etc anesthes Building & Construction 0 03-29-2011 06:33 AM
Cutting drywall side of basement stairs? Oxymoron Drywall & Plaster 4 10-07-2010 10:13 PM
Basement Stairs/ EZ Stairs mjkpainting Carpentry 8 02-24-2010 10:24 PM
Concrete Basement Stairs thomasd333 Building & Construction 2 12-26-2008 05:49 PM
